Throttle body remove and deep clean
Old Oct 27, 2019 | 08:56 PM
rh32's Avatar
Default Throttle body remove and deep clean
I have a 2006 LR3 4.0L V6 and would like to remove the throttle body, sit down and really deep clean it at a workbench, and then reinstall it. Are there any issues if I do this related to the computer or somehow syncing it to the car? I have heard that moving the throttle body while cleaning can result in the need to take it to a shop and have it remarried. Is this true?
Old Oct 28, 2019 | 12:30 PM
abran's Avatar
all good, remove and clean away.
Old Oct 28, 2019 | 03:18 PM
rh32's Avatar
Thanks - and not a problem if I open/close the throttle body while cleaning either?
Old Oct 28, 2019 | 07:14 PM
abran's Avatar
Nope!
Old Oct 28, 2019 | 07:23 PM
DakotaTravler's Avatar
I highly suggest if you are re-using the gaskets to thinly coat them with high temp sealant. New TB gaskets are cheap too though. When I serviced mine I had a random lean code. After sealing stuff it went away. Pretty sure the metal gaskets are one-time use.
Old Oct 28, 2019 | 08:34 PM
rh32's Avatar
Thanks for the heads up, will order a new gasket.
ClayinSA
Nov 29, 2017 10:15 AM
Broken08
Jun 28, 2015 03:29 PM
Danny Lee 97 Disco
Nov 25, 2011 11:12 AM
sebastian24
Oct 24, 2010 12:32 PM
bigugly82
Oct 15, 2007 04:18 PM
