Tow Hitch Reassembly (Oops!)
Old Apr 7, 2014 | 11:46 PM
drcoop's Avatar
Default Tow Hitch Reassembly (Oops!)
I lost the key to my Land Rover tow hitch... after reading on another forum how to remove the pin and pull off the green handle, I decided to clean and lube the mechanism, while waiting on my replacement lock handle from BPUtah. I removed the plate on the opposite side (held in by an allen screw). Well, I pulled out the rod that has the gear teeth and spring and greased them up. But now forgot exactly how the gear teeth were oriented. If anyone is doing something as stupid as I did, would you mind snapping a photo (with the side cover plate off) of the gear teeth orientation, from the side view, so that I know how to position/orientate the gear rod?
I'm waiting on my new part to re-assemble.
Old Apr 8, 2014 | 08:30 PM
roverguy7's Avatar
I've done the same before, and it is a pain to get back on right.
Only advice I can give is keep trying, it took a while, but I eventually got it back together and working, so know it can be done, but it is a pain.
Old Apr 16, 2014 | 06:43 AM
drcoop's Avatar
Thanks, you wear right.. I did figure it out. Just had to keep rotating the inner gear rod, re-assembling, try out the mechanism, and repeat until it worked....
dusty1
Dec 7, 2014 01:57 PM
momentum59
Jul 20, 2010 07:40 AM
meltdowndave
Dec 21, 2009 06:42 PM
carlitonsky
Jun 13, 2009 11:33 PM
S4poor
Feb 10, 2008 10:15 AM
