Transfer gear warning light flashing 2005 lr3
Old Jun 17, 2020 | 08:50 PM
Harold Espinal's Avatar
Those would seem like the logical things to do before even asking for help. Dive in, see if anything stands out. Otherwise its just a guessing game.
So the first thing I did is checked the battery condition it's good. I checked all the connectors at the transfer case and it is clean. I checked the transfer case module connectors and I found corrosion at the yellow connector terminals. I also opened the TCCM and found little bit of corrosion on it but no indication of chips being fried. So this was causing the suspension not to to up and range selector not to work?? Is there anything else I should be looking for??
Old Jun 17, 2020 | 10:34 PM
Globetrotter448's Avatar
Harold, do you have any error codes as this will help members
Old Jun 18, 2020 | 07:11 AM
DTC P0915 AND P186D from the transfer case module.
Old Jun 18, 2020 | 05:42 PM
Those codes could just be the gear selector linkage on the side of the box, a known problem. Could be the connector on the transfer box
Old Jun 18, 2020 | 05:52 PM
Found on the AULRO forum - could be the transfer case needs calibration.
So the fix was to start it, put it in neutral and re-select high/low range. I was going to try and prove it and write it up here but never did.
The thing I forgot under the pressure was the need to put it in Neutral to change Range, so had a few anxious hours.
This may be all that is required.
Old Jun 18, 2020 | 07:23 PM
DakotaTravler's Avatar
Confused, you can only change in neutral anyway.
Old Jun 18, 2020 | 08:37 PM
I have tried putting it in neutral and change the high and low range but i got nothing. Whats weird is that as soon you turn on the key it stays flashing on low range and dings like crazy.
Old Jun 18, 2020 | 09:09 PM
Sounds like it needs to be serviced/repaired. Could certainly be the solenoid. There is a thread somewhere on some forum giving the OHM readings. Search and see if you can maybe diagnose the solenoid. New part is about $80 and install requires drawing the fluid.
Old Jun 18, 2020 | 09:12 PM
Okay, i'm going to order one next Friday when I get paid, I hope this fix the problem. Is there any way I can manually change the low range to high?
Old Jun 18, 2020 | 09:21 PM
I can't guarantee that is the issue, should be tested first really. Although I have one to install even though mine is fine (preventative measure).
I know of no way to get it to shift manually. Might be a way with jumping the wires to manipulate it, but thats risky.
Try this though, get in and turn the key to II, then off, then back to II, then off and on the third time start it. Do this quickly though, no waiting for dash lights. But not insanely fast. This is a trick to get around some transmission and differential faults.
