Transmission Service
Old Feb 6, 2020 | 10:13 PM
  #21
Philip Chan's Avatar
Good question. Actually, I have two LRs that are going though this at the same time - The LR3 I have the 2 piece pan. New Bolts.
My L322 (2008) has the same transmission, but no tricky access issues. The Pan and filter are all in one like the original.
Old Oct 22, 2021 | 10:07 AM
  #22
hogweed's Avatar
The fill plug does not change location if you swap pans. The fill plug is not hard to get at.
yeah i was wonder how that location would change by changing the pan?
did we ever determine if any fluid that meets Shell M-1375.4 is acceptable for the ZF in the LR3?
Thanks
g
Old Oct 25, 2021 | 08:30 PM
  #23
DakotaTravler's Avatar
Yes, Motorcraft Mercon SP XT-6-QSP is identical to Lifeguard 6. Google if you feel like watching dead horses get beat, lol. Its brought up often enough across several car forums since more than just us need the stuff. Short of it was that when Ford owned Jaguar/Rover they need to produce the same spec fluid for serving them in the US. Its been even sent to a lab for testing to verify the fact its identical in spec. The only thing is the color is red, like most US transmission fluid. Checking Amazon its gone up in price to $115 from $85 for 12 quarts! But still A LOT cheaper than the "real deal". And I will add that not only do I use this Motorcraft fluid, others do too with no issues.
comleader
Nov 28, 2024 12:23 PM
Philip Chan
May 14, 2019 12:41 PM
Dv8er
Jul 13, 2017 03:19 PM
Roverrrgirl
Dec 8, 2016 04:51 PM
djkronik57
Nov 9, 2016 11:26 AM
