Turning off yellow brake pad permanently
Old Jan 24, 2014 | 12:26 PM
revscpa's Avatar
7th Gear
Default Turning off yellow brake pad permanently
I have a 2006 LR3 and have just replaced brake pads front and rear. I decided to forego difficult job of replacing pad sensors, cut the ends and tied metal portions of wires together. (I am **** enough and keep good records of what I have done.) Light continues to stay on. I even disconnected battery for 10 minutes. If both front and back sensors are tied up, is there something else that needs to be done?
BTW, I also have BMW X5 with same problem!
Thank you
Old Jan 24, 2014 | 01:50 PM
SuperBuickGuy's Avatar
you probably need to put some kind of resistor between the ends - most sensors have a range of acceptable values, zero or one are not acceptable. You may have to experiment to find the right resistor, but I'd look for something that reduces the voltage to (most sensors operate on a zero-5v reading) 3.
Old Jan 24, 2014 | 03:42 PM
spiderman's Avatar
the yellow light comes on for more than one reason. are you sure it is the wear sensors that are setting it off?
Old Jan 25, 2014 | 10:19 AM
revscpa's Avatar
7th Gear
Default Thank you
Over weekend I'll check other causes for yellow light. It also appears on X5 with same issue
doktorek
14
Jun 29, 2012 06:16 PM
sna77
Nov 18, 2008 06:23 PM
Disco2Guy
Mar 3, 2008 10:51 AM
Mark G
Oct 23, 2007 03:08 PM
RamblingMan
Oct 17, 2007 08:28 AM
