U0167 Code: Hard Reset Not Fixing the issue
Old Jul 24, 2025 | 08:21 PM
  #41
cybercop's Avatar
Well, I SAID fixed.
The truck has been running beautifully and all of the sudden, while sitting in the parking lot waiting for my son, TPMS light started flashing, A/C went off, heard the click of the door locks, radio said System Fault System shutting down, all the usual symptoms.
Have not scanned for any codes now that I have my GAP.
Just odd, everything was going right.
I inspected the wiring harness when I installed the "new" used donor Cluster. It looked great. Is it possible there is still a issue at the harness and the motion of unplugging the old cluster and putting in the donor helped something? Could it be another bad cluster? Another module that is in the chain?
I guess it could be a yes to any of those questions. Just it was terrible and always going crazy until I put in the donor cluster. Pure bliss for several days.
Anymore thoughts?
Old Jul 24, 2025 | 08:35 PM
  #42
DakotaTravler's Avatar
What the..... Ugh.... I suppose it is possible the replacement cluster has one tiny cold solder joint. But if we look back there was suspicion of power/ground, etc. And while at idle the alternator is sorta putting out just enough to get by and charge the battery if needed. Guess we need some codes and maybe check voltages at longer idle times. I forget, was the battery ever swapped for another? A bad battery can show 12v all day while also having a bad cell or a short between two cells, which can cause some weird crap too. So there is still the chance you had a bad cluster and [insert random Land Rover issue here].
Old Jul 24, 2025 | 09:44 PM
  #43
loanrangie's Avatar
That would be my guess, pretty much most clusters from the this year range can/will fail at some point so i'd look at getting your original one repaired.
Old Jul 24, 2025 | 11:23 PM
  #44
cybercop's Avatar
Yep, battery was swapped with a new one. IF, it acts up tomorrow, I will immediately pull codes.
Old Jul 27, 2025 | 05:21 PM
  #45
cybercop's Avatar
OK, in the truck now and cranked the truck and waited for the AC to out, flashers going, no side turn signal activity etc. Clusters shows not temp on the temp gauge and my TPMS light flashing and continuous.
While truck running and sitting parked, it started the acting up.
Check faults with GAP tool, and I only get the erroneous "invalid roof position" code. No other codes.
Should I be getting something else?
Old Jul 27, 2025 | 05:34 PM
  #46
cybercop's Avatar
OK, hit advanced under Faults and turned everything on in the GAP tool.
Now I get this (can ignore the suspension and other faults unless you want extra credit on what is going on with suspension)
​​L319 - LR3 2007
Vehicle scanned on 27-07-2025 16:23
Using IIDTool BT V4.0 B0338
Instrument Pack
  • U0010-88 (26) Medium speed CAN communication bus - Bus signal/message failure - bus is off
    ( on 27-07-2025 16:12:45 at 147325 mi )
    - Test Failed This Monitoring Cycle
    - Pending
    - Test Failed Since Last Clear
  • U0184-87 (26) Lost communication with audio unit - Bus signal/message failure - missing a message
    ( on 27-07-2025 15:39:45 at 147325 mi )
    - Pending
  • B1A87-68 (50) Battery disconnection/electronic control unit reset - Algorithm based failure - event information
    - Test Not Completed
    - Test Not Completed This Monitoring Cycle
Steering Angle
  • U0122-87 (2F) Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message
    ( on 27-07-2025 16:13:46 at 147325 mi )
    - Test Failed
    - Confirmed
  • U1A14-49 (50) CAN initialisation failure - System internal failure - internal electronic failure
  • C0051-64 (50) Steering wheel position sensor - Algorithm based failure - signal plausibility failure
Suspension
  • C1A31-01 (50) Front left corner valve - General failure information - general electrical failure
  • C1A32-01 (50) Front right corner valve - General failure information - general electrical failure
  • C1A33-01 (50) Rear left corner valve - General failure information - general electrical failure
  • C1A34-01 (50) Rear right corner valve - General failure information - general electrical failure
  • C1A37-01 (50) Front cross-link valve - General failure information - general electrical failure
  • C1A38-01 (50) Rear cross-link valve - General failure information - general electrical failure
  • C1A24-67 (50) No temperature increase when compressor requested - Algorithm based failure - signal is incorrect after the event
  • C1A18-64 (50) Pressure increases too rapid when filling reservoir - Algorithm based failure - signal plausibility failure
  • C1A24-64 (50) No temperature increase when compressor requested - Algorithm based failure - signal plausibility failure
  • C1A29-92 (50) Switch activation too long - Component failure - performance or incorrect operation
  • C1A03-26 (50) Front left height sensor - General signal failure - signal rate of change is below the threshold
  • C1A03-92 (50) Front left height sensor - Component failure - performance or incorrect operation
  • C1A04-26 (50) Front right height sensor - General signal failure - signal rate of change is below the threshold
  • C1A04-92 (50) Front right height sensor - Component failure - performance or incorrect operation
  • C1A05-26 (50) Rear left height sensor - General signal failure - signal rate of change is below the threshold
  • C1A00-49 (50) Control module - System internal failure - internal electronic failure
  • C1A05-92 (50) Rear left height sensor - Component failure - performance or incorrect operation
  • C1A06-26 (50) Rear right height sensor - General signal failure - signal rate of change is below the threshold
  • U0133-87 (50) Lost communication with dynamic response module - Bus signal/message failure - missing a message
  • C1B19-03 (50) Door status signal - General failure information - frequency modulation/pulse width modulation failure
  • C1123-1C (50) Steering isolation valve supply circuit - General electrical failure - circuit voltage out of range
  • C1A06-92 (50) Rear right height sensor - Component failure - performance or incorrect operation
  • C1B18-62 (50) Supply voltage x-ref check - Algorithm based failure - signal compare failure
  • C1A07-62 (50) Cross articulation - Algorithm based failure - signal compare failure
  • C1A00-1D (50) Control module - General electrical failure - circuit current out of range
  • C1A20-64 (50) Pressure increases too slow when filling reservoir - Algorithm based failure - signal plausibility failure
  • U0136-87 (50) Lost communication with differential control module - rear - Bus signal/message failure - missing a message
  • C1122-01 (50) Steering isolation valve - General failure information - general electrical failure
  • U2007-67 (50) Valve(s) circuit - Algorithm based failure - signal is incorrect after the event
  • C1130-7A (50) Air spring air supply - Mechanical failure - fluid leak or seal failure
  • U0434-86 (50) Invalid data received from dynamic response module - Bus signal/message failure - signal is invalid
  • C1139-23 (50) Unknown
  • C1138-23 (50) Access switch - General signal failure - signal stays low
  • C113A-64 (50) Wake-up control - Algorithm based failure - signal plausibility failure
Terrain Response
  • C1A02-94 (50) Rotary encoder stuck in the intermediate position - Component failure - unexpected operation
  • C1A01-96 (50) LED circuit - Component failure - internal failure
Transfer Case
  • P0903-00 (50) Clutch actuator - circuit high
  • P0902-00 (50) Clutch actuator - circuit low
  • P0900-00 (50) Clutch actuator - circuit/open
  • U0155-87 (2F) LCD Gauge Communication Lost - Bus signal/message failure - missing a message
    ( on 27-07-2025 16:13:41 at 147325 mi )
    - Test Failed
    - Confirmed
Transmission
    - Test Failed
    - Confirmed
Old Jul 27, 2025 | 09:35 PM
  #47
cybercop's Avatar
While trying to find the stupid drain from the AC which is supposed to be next to the left side of transmission, I stumbled upon this. Not sure if it is related to the "cluster" issue, but when I start working on the suspension, I think that is what we call in law enforcement as a clue.
was getting no compressor temp readings other than 9 degrees C with no changes on the thermistor .
Old Jul 27, 2025 | 09:40 PM
  #48
Dam.... you are a glutton for punishment. I dont think any CAN BUS wires are there, but I could be wrong since I am not certainly which way the ABS bus wires are routed and Rover did some weird ****. As for prior post, I know steering angle can really mess with some things like ABS, suspension, etc. Lots of warning when it is defective or out of calibration.
Old Jul 27, 2025 | 10:16 PM
  #49
cybercop's Avatar
Is this the Interior drain hose for the A/C next to the LHD gas pedal? If so, Mine is in what I would call great condition without a drop around it.
Old Jul 27, 2025 | 10:19 PM
  #50
Brake pedal. But yes, that is it. There is one on each side but the issue is not if they look nice or not, they usually do actually. But they can clog up and prevent draining and then the HVAC box itself just leaks all over. Give it a gentle side to side twist as you pull down on that tab. It should pop odd easily enough. If you get a gush of water, you have an issue. I take water bottle with the pop-up thing on top and squirt those into them to clear. But they are not long, so almost anything can be poked down em.
