V8 timing chain tensioners
Old May 5, 2026 | 01:53 PM
markwemple's Avatar
Default V8 timing chain tensioners
Ming chain tensioner noise on my 07, I think. We are getting about a 1 to 2 second noise on start up on the top front driver's side of the engine. On the AJ26, the secondary tensioners were the biggest problem. Anyone ever just done those, or just open it up and look at rails, primaries, the works. It has 176k, but this noise just, and I mean just, started to happen and it really is only there.
Old May 5, 2026 | 05:30 PM
DakotaTravler's Avatar
There is a more likely chance it is the VVT assembly if you are only getting it at startup. But if it is the timing chain components they are pretty basic in design and straight forward to replace. Further diagnosis may be needed to be certain. If it is VVT related, you can run it for years without issue.
Good thread to look at with a ton of pics....
https://landroverforums.com/forum/lr...cement-111381/
Old May 5, 2026 | 08:37 PM
markwemple's Avatar
What repairs can be made to the vvt?
Old May 6, 2026 | 11:43 PM
cybercop's Avatar
Dakota, What other diagnosis would you do if you are not getting codes?
Old Yesterday | 02:07 AM
markwemple's Avatar
So, doing some homework, the vvt solenoid could be leaking after the engine turns off. Doesn't look like an expensive part, unless I'm looking at the wrong part?
Old Today | 12:00 AM
cybercop's Avatar
I think they are talking about these Part Number: W0133-1777363 and they ae not cheap? About $750 each. Can anyone verify this
Jezzaron
Discovery Sport
Nov 21, 2022 08:18 AM
BB22
LR4
Aug 12, 2021 11:17 AM
killerpav
Jan 18, 2016 08:46 AM
discofrost
Apr 2, 2012 05:32 PM
RED
Apr 30, 2008 11:37 AM
