Various random faults - system shutting down
Old May 9, 2020 | 10:13 PM
  #21
marcodolo's Avatar
3rd Gear
Originally Posted by c00mtg
My issues: Won't start sometimes unless i wait a few minutes. If it starts, and while driving, i get the "system shutting down" on the radio (navigation, radio turns off, cabin lights turn on, doors start to lock/unlock on their own, hazard lights stay on. I replaced the brake light switch, new battery. I'm thinking in inspecting the ECU and TCU? to see if there's corrosion? Checking all wires around battery and ECU/TCU to make sure they have good connections? Water damage on fuse boxes?
I'm also having these issues on my 2009 range rover hse with 99.6k miles. When the problem first occurred I had the codes ran and I got a U0167 (Lost Communication With Vehicle Immobilizer Control Module). Whenever I turn the key I get all types of faults these include TPMS, Parking brake, brakes, and HDC fault system unavailable. I'm curious if any of you guys also get / had these all these faults. Also what is the name of the company that will repair the IC in washington? Thanks
Old Jun 1, 2020 | 05:42 PM
  #22
c00mtg's Avatar
6th Gear
Default Update, Follow up FIX
Hi all, just wanted to give everyone an update.
As stated above on my notes, I received the cluster back from clusterfix.net took me about 30 mins to put it back in. My RR has been working fine with no issues or lights. The company i use is very familiar with the issue. They are very familiar with the issues below:
  1. Intermittent or inoperative instrument cluster
  2. No communication with cluster via scan tool and setting of lost cluster communication U codes.
  3. No start condition with inoperative cluster with MSP CAN BUS problems
  4. HDC unavailable message coming up in message center
  5. Hazard lights turn off and on by themselves
  6. No turn signals
  7. Door locks locking and unlocking by themselves
  8. HVAC going off and on
  9. Misc. warning lamps illuminated
  10. Error Messages appearing on center display screen
  11. No data on display screen
  12. Using trip button affecting cluster operation
i would give them a try. Took about 8 days to get it back.
Old Jul 16, 2020 | 09:16 AM
  #23
ThierryNL's Avatar
Hello,
Im new here, i'm from Holland and having the same issues.
They fixed my cluster 2 days ago, because it was falling out sometimes. Verry Annoying .
Now the car wont start, hazard lights flashing, door locks automatically, HDC fault, Transmission Fault, ABS light on.
I have an Autel Maxidiag, it have some fault codes, But i think code U0155-87 is the most important. Communication with Cluster passed away.
So i will bring my cluster back to the company who fixed it 2 days ago.
I hope they can solve it. Does anyone have some tips for me?
Thank you verry much
GR Thierry
Old Jul 29, 2020 | 10:59 PM
  #24
Teddy Gibson's Avatar
Do you mean clusterfix.net repaired your cluster and now it doesn't work?
Old Aug 23, 2020 | 06:51 AM
  #25
jbullock78's Avatar
Just had this done with mine 2007 LR3 71k miles. 1700 dollars rebuild the cluster and reprogrammed.
LewistonLR
May 11, 2020 09:04 AM
06Range
May 8, 2013 09:01 PM
GWDRoverTX
Jan 16, 2013 10:22 PM
