Vibrations / Noises in low RPM 5th & 6th gear
Old Dec 28, 2023 | 01:55 AM
andregustafson's Avatar
Default Vibrations / Noises in low RPM 5th & 6th gear
Dear fellow Discovery owners
I'm experiencing two different types of vibrations / noises in low RPM's in fifth and sixth gear. When the cruise control is activated the RPM's go up and down as well.
I've talked to a couple of different mechanics here in Sweden, including a dealership but they seem to be clueless about this issue.
I would very much appreciate if anyone could help me shine a light on the issue and a possible solution?
Thanks in advance & Best regards, André
Old Dec 29, 2023 | 11:51 PM
DakotaTravler's Avatar
If RPM and fluctuating (going up and down) it might be some form of torque convertor shutter. When was the transmission fluid last changed? Automatic transmission I assume? There are other possibilities, but we need to narrow it down.
Old Jan 7, 2024 | 10:10 AM
Thank you for your@DakotaTravler . It has automatic transmission yes. I'll get the transmission fluid changed now and then get back to you if the problem persists 👍
Old Jan 7, 2024 | 06:59 PM
loanrangie's Avatar
What is the mileage, does sound like the torque converter is failing.
ryanmccarrel
Aug 14, 2021 12:18 PM
archaeology_student
Sep 8, 2014 08:07 AM
Lion Heart
Mar 16, 2012 03:52 PM
Kevinmward
Nov 5, 2010 09:12 AM
sn1987
Aug 15, 2009 09:17 AM
