Weirdness after air spring change
Hey all! I replaced an air spring several months ago and used my Snap On Solus Ultra to recalibrate ride height afterwards. Ever since when I select entry height mode it indicates as Off Road mode on the 4x4 screen. The LR3 is in entry mode but it reads off road. Not a big deal until we were in a parking garage where we HAD to be in entry mode for height restrictions and I heard the air compressor kick in! I believe we stayed in entry height but it made us nervous. So the question is....how do I get my screen to display the lower mode when LR3 is set to entry mode. It indicates properly for normal and off road modes so I am scratching my head. I tried recalibrating again and ended up with the same results.
Is the problem with the Snap On programmer not completing something that a Rover dedicated programmer would handle? Any help I can get is appreciated. My buddy has the iLand programmer but we have not tried that yet. I thought I would ask for opinions before we mess around any more.
I don't think re-calibration is typically required after a spring-swap. That said, your best move is to buy an IIDTool anyway. It will pay for itself, and it can also help you diagnose this problem.
I believe Houm is correct a recalibration was likely un-needed. I would try the rover specific programmer as recalibration can be a bit tough to accomplish and I haven’t heard of it being done successfully with a non-rover specific tool
Ok thanks guys! I watched an Atlantic British video and he said recalibration was necessary so I did that. I called an independent shop today that specialized in Rovers and they told me to double check the ride height arms to make sure one isn't bending the wrong way. So I will check that too and likely first before I try recalibrating with the iLand.
bigmac
Dec 2, 2008 10:21 PM
