Wet floorboards. Fixes not working. Help!
Old Apr 15, 2019 | 03:55 PM
jmac's Avatar
Default Wet floorboards. Fixes not working. Help!
2006 LR3 SE - I've had water soak both driver and passenger side floorboards over the past several years. I have recently replaced both sunroof drain hoses and replaced the lower windshield cowl. Just had a big rain and guess what, the floorboards were wet. Not soaked, but damp. What am I missing? Where else could water be getting in?
Thanks!
John
Kansas City
Old Apr 15, 2019 | 04:01 PM
DakotaTravler's Avatar
There are typically three entry points:
Sunroof drains (front and rear)
Cowl
A-pillars
Did you service the exterior a-pillar trim?
File Type: pdf
Old Apr 15, 2019 | 04:08 PM
jmac's Avatar
No, I have not serviced the A pillar yet. I will look into it immediately. Thank you!
Old Apr 15, 2019 | 06:04 PM
Blackngold77's Avatar
Thanks!
John
Kansas City
its only like $100 total. worth it to just buy new A pillar covers. Thats almost certainly where its coming from.
30 second repair and no tools needed. just pull the old ones off, line the new ones up and hit em down with your palm
Old Apr 16, 2019 | 12:21 AM
houm_wa's Avatar
Default $100?
Where are you sourcing A-Pillar trim pieces for $50 each??
Old Apr 16, 2019 | 07:19 AM
haha, guess my memory failed me.
revised...only $165 total
Old Apr 16, 2019 | 08:59 AM
MIKE@LK8PARTS's Avatar
Former Sponsor
I work for a company called Lucky 8 in Clarence Ny i have these A Pillars in stock the pair would be $ 200 shipped if interested please email me at miker@lk8parts.com thank you
Old May 11, 2019 | 06:04 PM
06LR3HSE's Avatar
Have you blown out the AC drains on both sides?
Old May 11, 2019 | 06:14 PM
jmac's Avatar
I have not done that. I ended up changing the A pillars and no longer have water in the floorboards. But guess what, we had a gigantic rain last week and there was water in the dome light. That has never happened. So now I've got to figure that out...
Old May 11, 2019 | 06:53 PM
Sunroof drains.
They're on the L and R front corners of the sunroof tray.
Passenger side exits behind the side grille. Pop off the grill and snip the end off the drain (clog point).
Drivers side is a little trickier. Pop off the wheelwell shield and reach up towards the steering wheel in that cavity. Best bet is a razor blade to add slices.
Also blow air from the top through the drains to clear it out
AJ1
Oct 23, 2019 08:25 PM
DiscoBuckeye
Dec 14, 2018 08:37 PM
Lee13
Jan 31, 2018 08:55 PM
CATTIVA73
May 23, 2016 06:19 PM
comleader
Jan 1, 2015 10:08 PM
