What did you do to your LR3 today?
Old Dec 25, 2021 | 09:18 AM
  #1821
tracyc's Avatar
If you do take off that inner fender liner, that's a good opportunity to clean up those ground wires and studs that are then accessible as well.
Originally Posted by Captain Sygo
Thanks! I took the plunge for a new OEM Denso and replacement battery was free due to warranty. The new alternator is not here yet but I got the bad one out. The video at this link was really helpful:
https://youtu.be/p-El3ANScU8
The only thing I would add is that I found it MUCH easier to get at the innermost bolt and the plug connector after taking off the large, inner splash guard. Getting that removed isn't too bad and does not require completely removing the wheel arch trim if you flex the splash guard as you pull it out.
Old Dec 25, 2021 | 10:26 AM
  #1822
Captain Sygo's Avatar
Thanks for the suggestion. Can you point me toward something more specific? This is my first time working in that part of the engine bay so I don't know where all the critical ground spots are to clean up.
Old Dec 26, 2021 | 12:47 PM
  #1823
tracyc's Avatar
The ground lugs are very obvious when you take the passenger side fender liner off. One is underneath the battery tray area and the other is towards the front pretty near the alternator. In a post updated this week there were pics that show exactly what you need. If I'm able to find it I'll post a link.
Old Dec 26, 2021 | 12:52 PM
  #1824
tracyc's Avatar
Ok, read the last few responses on the thread linked below, then follow the link I posted at the end. That's where you'll find some helpful photos of the grounding lugs inside the fender well:
https://landroverforums.com/forum/lr...64/#post805132
Old Dec 26, 2021 | 02:17 PM
  #1825
Fantastic... thanks much!
Old Dec 28, 2021 | 11:22 AM
  #1826
martinezparamounttkd@gmail.com's Avatar
Had a heck of a time swapping out the driver rear cv axle… Can’t get the new axle pushed in all the way??? Any help would be awesome!
Old Jan 3, 2022 | 06:17 PM
  #1827
Alex J's Avatar
Try putting some grease on the splines an locking clip, If that doesn't work try taking the locking clip off of the old axle and put it on the new one. More than once during my career as a BMW tech I ran into the issue of the new clip being not quite right and preventing the new CV axle from fitting. I also ran into that issue upgrading the axle shafts in my friends 80 series Land Cruiser where the new clips wouldn't fit into the knuckle joint, swapped the clips and they locked right in.
Old Jan 10, 2022 | 12:59 PM
  #1828
Amadreas's Avatar
Default Interior rear upper hatch manual lever handle installed…twice
Installed a rear interior upper hatch manual release handle from Landrover passion.com.
Had a brain fart after installing it. While standing outside with the upper hatch open, lower closed. I was pulling the lever and wondering why the bottom tailgate wasn’t opening, took it all apart again until I realized that it releases the upper hatch.
Freshly installed lever handle
Old Jan 11, 2022 | 10:24 PM
  #1829
Alex J's Avatar
Hauled one of the last loads of stuff from my old house to our new house today. Never pulled a trailer any sort of distance before this last week but the LR3 made it easy. Backing up is a little tough, and it doesn’t help that the street my new house is on isn’t wide enough for 2 cars to pass if there is one parked on the street. And to make it even more fun my driveway is only 7 feet wide.
Old Jan 18, 2022 | 08:24 AM
  #1830
soarvet's Avatar
Installed a new phone holder. I'd highly recommend the Quad-Lock system.
