What did you do to your LR3 today?
Old Sep 3, 2018 | 09:31 PM
  #681
EastCoast's Avatar
Originally Posted by Best4x4
Changed the spark plugs out on my wife's 06 HSE. I "was" planning on going with NGK's as that's what it came with off the factory floor, but they're not so easy to find 8 in-stock in my neck of the woods. I laughed when I noticed the LR3 took the same exact spark plug as my older D2's. I've had excellent results with Autolite XP Iridium plugs in my D2's so that's what I went with in the LR3. While I was at it I cleaned the throttle body plate and was happy to find it pretty clean. Also replaced the drivers side A Pillar Exterior trim that decided to explode going down the highway not to long ago.
Did any of the plugs give you grief and do you have any tips if they did?
Thanx...
Old Sep 4, 2018 | 09:03 PM
  #682
Best4x4's Avatar
Nope very easy job, on the drivers side once you remove the silver heat shield (one phillips head holds it into place) access is clean and simple. Passenger side has two heat hose lines nearby, but they didn't bother me.
Old Sep 7, 2018 | 04:55 AM
  #683
loanrangie's Avatar
Got the best accessory so far for the D3, GAP IID BT tool, should pay for itself in no time. First thing to do add 20mm to the ride height.
Old Sep 7, 2018 | 09:52 AM
  #684
bbyer's Avatar
Default yes, to the transfer case
Originally Posted by 03discotrayer
Worked on the lr3 for 6ish hours today
I drained the transmission, removed the pan, pulled the valve body, replaced the solenoids, installed the new filter and pan, refilled the transmission, road tested, and it is shifting like a dream, before it felt like you would get rear ended coming to a stop, you could feel 3rd to 2nd and 2nd to 1st also had an issue a few times from 3rd to 4th and it would go into limp mode. Now it is awesome and shifting as it should. In a few weeks I'm going to be doing the diff oils; has anyone done the transfer case
I kind of have a rotation plan re oil changes so eventually the transfer case gets changed as well as all else.
If it was a Ford, Chev or Dodge, probably never, but with the 3, I think new oil in everything once in a while is good preventive maintenance - and it gives you a chance to see if any chunks are in the oil.
Your 3 looks real good in the jpg's above. Is that some sort of tow hook underneath that is visible in the first picture?
Old Sep 13, 2018 | 01:29 PM
  #685
BenSchneider's Avatar
6th Gear
Just thought I would share my most recent journey. It began with moving my passenger seat and triggering the airbag fault. After pulling the seat and looking for bad connections and re-seating all the connectors (and in the process learning all about the electrical system in the seats) I finally found mention online that the error light will not reset without a LR scan tool. Do I spend $200 on a scanner or $550 on the GAP IID BT?
Well I have been living with 1 key fob for 5 years so it's about time to quit tempting fate, and get another. I bought the GAP tool from Lucky8 ($512, free shipping, no tax) and a refurb key on ebay ($90).
What a great tool! First was reading the error codes. There were many, dating back to 2014. I saved them for later reference and reset all the codes. I am happy to say the airbag fault cleared and has not returned.
Next was the key. With the GAP tool, this was a simple, 10 minute process. It worked just like it was meant to. Then I found a locksmith that could cut the key (there are not many) and now I am all set.
I am looking forward to digging in to all the other tasks I can perform with this tool.
Old Sep 13, 2018 | 02:08 PM
  #686
I got home from Duty and drove my LR3 for the first time in 5 weeks. I missed my truck.
Old Sep 13, 2018 | 02:19 PM
  #687
houm_wa's Avatar
Default Five weeks?!?!
Did you have it on a battery tender? Any issues with the fuel destabilizing?
Old Sep 13, 2018 | 03:09 PM
  #688
No I didn't and I didn't notice any issues with drive-ability. Drove it about 40 miles today and topped off the gas with fresh before heading home.
Old Sep 13, 2018 | 04:19 PM
  #689
houm_wa's Avatar
Wow, 5 weeks and no battery issues, that's impressive.
I'm not sure I can do that.
Old Sep 13, 2018 | 04:24 PM
  #690
She cranked right to life, no issues. Made me happy. She needs washed something fierce but we have a hurricane/tropical storm/big wind thing bearing down on us so washing it seems a bit pointless today.
Taking it tomorrow to have the wheel balance checked I think I threw a weight or two on a tire.
