wiper cowl
Old Jan 5, 2011 | 09:03 PM
dragan's Avatar
Default wiper cowl
Hi guys
Do anybody know steps haw to remove wiper cowl .
Thanks
Old Jan 15, 2011 | 10:00 AM
jimbiram's Avatar
remove the wipers from the posts. Then the whole thing just snaps off. There are clips behind it that holds it in place. I watched a window guy just slide something flat behind it by sliding down the window at one end and just worked along to the other side.
Old Jan 25, 2011 | 06:14 PM
paulstring's Avatar
Why? Is yours warped?? LOL... I'm sure it is or will be shortly. I told my local LR dealership that they should try making those out of a different type of plastic so it lasts more than about 3 years.
Old Jul 27, 2012 | 07:30 PM
robersonb's Avatar
I just got my cowl loose. It was pulling away in the center slightly as well. What I have found is that there is only the one bolt holding it firmly down which is easy to get to. There is a plastic clip on each side and one in the center. My center one is still there but clearly broke. The driver's side is cracked which tells me it has little to no holding strength. You can't see the clips until it is loose. If you use a panel popper or something like, I would try and slide it from the top of the housing down. To get it completely off, you will have to take the hood off. DiscoMike told me to remember to use a magic marker to mark the hood layout from the brackets on the hood to make putting it back on easier when finished.
Old Jul 28, 2012 | 10:16 AM
unseenone's Avatar
All these cowls eventually warp. I did a write up on how to check it and change it. Here is a link to the write up.
None of this operation required removing the hood, I am not sure what operation was being performed there.
One main reason why it is important to check / change is because the warp develops right above the cabin air intake, and can damage electronics and the blower motor when it leaks.
sayeedA
Aug 30, 2012 01:52 PM
pippagirling
Feb 24, 2012 11:54 AM
DaveBFoto
Jun 10, 2011 12:22 PM
rewi9d
Nov 25, 2010 11:35 AM
jafir
Apr 10, 2010 09:12 PM
