Wiper issues
Old Feb 27, 2022 | 04:25 PM
Baja1967's Avatar
3rd Gear
Default Wiper issues
When try to use the front windshield washer function the fluid flows, but the back wipers come on, not the front…when I try to use fluid on the back, the fluid flows, but the wipers don’t…2005 LR3 SE
Old Mar 1, 2022 | 12:44 PM
DakotaTravler's Avatar
Probably a broken multifunction switch. The CJB controls the wipers based on inputs, so its likely receiving erroneous ones. If you have a GAP tool there may be a way to read live inputs as you operate the stalk, but I have not looked to see if that is possible. I would recommend simply replacing the assembly. My neighbor picked up an LR3 were the rear wiper never turned off. Replacement of the stalk assembly worked.
Old Mar 1, 2022 | 12:45 PM
Here is a PDF with some info.
File Type: pdf
kennym
Apr 11, 2025 12:02 PM
Rick Nelson
LR2
May 8, 2020 09:20 PM
A5scott
Sep 9, 2011 10:35 PM
hilltoppersx
Sep 22, 2010 07:44 PM
McGuido2008
Nov 12, 2007 12:22 AM
