Wont Completly Shift into Drive
Old Aug 16, 2015 | 06:06 PM
nicksrover's Avatar
Default Wont Completly Shift into Drive
Wife said she went to pull in to post office the other day and car just revved up like it was in neutral. She was able to get it thrown back in to Drive and go. I didnt think to much about it but I have taken a look at it and I dont see anything obvious that is causing the problem. I am hoping this is a linkage problem, and not a problem inside the tranny.
Does anyone know of this issue
2006 LR3 with 4.4
Old Aug 17, 2015 | 08:46 AM
unseenone's Avatar
Sounds like a new one. I would look at the shift linkage, particularly if you are in a rust belt.
If the brake light switch is acting up, it would prevent shifting at all. Here are some other bits to look at.
Shift Components
LR012704 - Lever
WYH000040 - Nut - flanged
VYH500020 - Nut
TYG000050 - Bolt
TZT500040 - Bush
TYF000050 - Washer - spring
Old Aug 17, 2015 | 09:40 AM
bbyer's Avatar
Default shift linkage info
The link below to a 47 page pdf shows the gearshift linkage on page 33 of 47.
This may be of some help as the text within explains what the linkage is connected to.
DISCO3.CO.UK Photo Gallery - ZF 6HP26 Automatic Transmission in LR3/ZF 6HP 26X Description and Operation
The link below is to a great number of files re our ZF 6HP26 tranny.
Below is a link to brake light switch info. Check your front and rear signal lights for correct operation and the two rear brake light bulbs. If all seems to be working OK, are all bulbs genuine, or are some of far east origin?
Have you replaced a bulb recently? Bulbs problems can show up as tranny problems.
DISCO3.CO.UK Photo Gallery - Brake Light Switch Replacement
sjewell
Sep 12, 2019 11:55 AM
importdave
Sep 25, 2014 10:18 PM
kerryslemon
Oct 21, 2011 04:45 AM
Prowler9876
Feb 8, 2010 05:53 PM
