2011 LR4 5.0 Head Gasket replacement documentation
Old May 12, 2020 | 10:50 PM
  #51
AGLR's Avatar
Engine Tech Machine in Santa Maria, California with a 24hr turn around time on resurfacing the heads!
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200512_204808.jpg
Old May 13, 2020 | 05:04 AM
  #52
huggi's Avatar
24 hrs is impressive. How much did they take off? Are you going to use head shims? I'm still waiting on my machine shop
https://www.innomach.com/images/IMS-CATALOG.pdf
Old May 14, 2020 | 12:16 AM
  #53
AGLR's Avatar
I was told that only about 0.008 was taken off. Not enough to need shims.
Old May 14, 2020 | 06:45 AM
  #54
huggi's Avatar
What's the cutoff? I'm still waiting to hear from my machine shop regarding how warped my head's are
Old May 17, 2020 | 03:08 AM
  #55
AGLR's Avatar
I'm not aware of a cutoff, but I'm not concerned about 0.008. Did you come across any specs for that?
Getting the heads back together this weekend. Looks like I'll have to get some new tappets to set the exhaust valve lash back to spec (.25mm +/- 0.02). I'm closer to 0.3 to 0.38. Not surprising after 120k miles though. At least the intake side is hydraulically adjusted.
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200517_010936.jpg
Old May 21, 2020 | 10:14 PM
  #56
huggi's Avatar
Any idea where to find the left hand thread crank pulley bolt - that says 12.9 on the front. The only part number I can find LR011952 does not mention reverse thread. Also, do I need one of those spacers too?
Thanks
Old May 22, 2020 | 11:48 PM
  #57
AGLR's Avatar
Thanks
That bolt is solid, I'm reusing mine.
Old May 30, 2020 | 03:12 AM
  #58
AGLR's Avatar
Heads back on top.
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200530_010609_capture.jpg   2011 LR4 5.0 Head Gasket replacement documentation-20200530_010603_capture.jpg
Old Jun 1, 2020 | 02:25 AM
  #59
AGLR's Avatar
All head bolts torqued through sequence
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200601_002403.jpg
Old Jun 1, 2020 | 02:26 AM
  #60
AGLR's Avatar
Mix of new and old tappets to return valve clearance back to spec after new exhaust valves.
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200531_205324.jpg
