2011 LR4 Engine Knock Idling
Old Nov 28, 2024 | 09:07 AM
  #41
roverraj's Avatar
8th Gear
Originally Posted by grammin
Hi, been a while since I posted here. I have a 2011 LR4 , 188,000km. I've had it for 5 years since 133,000km. My research showed the timing chains were completed before I bought it at a reputable dealer in the Toronto area. The engine has always been strong and I have changed the oil frequently. I also added a Liquid Moly fuel cleaner about a year ago. The engine sounds pretty good, until I get the knock. To me it comes from the area of the Fuel Pumps. I thought it might be the tensioner in the oil pump/ fuel pump chain in the sump. But it is intermittent, shows up at idle (drive thru's are typical when you can hear the engine reflecting noise off the wall with your window open). It has been there since I got the car. It has bugged me but is yet to cause any failure. I'm not really answering the question as I have not solved the problem but just wanted to highlight that it's been there since I owned the vehicle (over 50,000km now). I get good fuel pressure and the engine is strong and revs freely.
It can be quite loud and disconcerting, nevermind the loss of credibility lol. Has anyone replaced the fuel pumps?
I just remembered, today I was changing the oil and the knocking started when I was heating the engine. Because I had the engine cover off, I actually put my finger on the fuel rail and I could feel the knocking vibration. Not sure if that's a clue!
Hey, I’m also located in the Toronto area and looking at an LR4 as a potential future car! I would love to pick your brain given the chance
Old Nov 28, 2024 | 10:12 AM
  #42
guy's Avatar
guy
FWIW, the mechanical HPFPs on my 40 yo marine diesel are much louder. And immensely dependable.
It is nothing to worry about. In fact it makes me grin as its "old school". But I do only use highest grade fuels.
See: https://www.toptiergas.com/gasoline-brands/
Equally, preventative maintenance is paramount. I change oil and filter every 5000 km. Causes for the premature wear have highlighted areas of concern like oil starvation, oil oxidation and contamination.
As I shared in another post, in another forum, I personally know of an F150 with essentially the same engine at 325,000 km, never needing any kind of involved repair or rebuild. It is a work truck being driven hard. And maintenance is key.
Cheers.
Old Feb 12, 2025 | 11:25 PM
  #43
valadas's Avatar
3rd Gear
Originally Posted by Lothar52
I don’t own a LR but a 12 XKR 5.0L Jag…. Same engine same problem…. Ticking on warm restart the worst.
when I start my car cold it’s not there. If it was a loose timing chain tensioner you would hear a cold start chatter…. I know I had one!
this noise comes after maybe 5-10 min at a stop light and you hear it inside the car. The. By the 3rd or 4th stop light trying to get on the freeway is improved or gone.
i watched a video about the HPFP system on these engines and the guy talks about how awful it is… “your gonna get excess noise and it’s coming from the Hpfp lower right side…. Your gonna be replacing these In pairs”
Here is the main issue we are having. I’ve not seen one person comment they replaced their HPFP, cam followers, and HPFP rails with resulting improvement or cure? Has anyone actually done this? I know I have not but have the parts on order for my indie to get done..
Hi Lothar52,
have you had your HPFP’s replaced? Did the noise go away? I’m also living with that annoying noise, and willing to replace the pumps, if that’s the cure.
Thank You
Old Feb 23, 2025 | 09:08 PM
  #44
BigChillin's Avatar
Originally Posted by jaguardoc504
Any model with the 5.0 can have the noise I'm referring to. It presents any where from a tick to a low level knock at idle, but goes away when RPM's are increased. Once you know what it sounds like you can hear it on almost all of them.
do you have a video of it?
scottharrah
LR4
27
May 4, 2023 02:42 PM
CB7010
LR4
19
Nov 17, 2022 10:11 PM
john_greg
LR4
Nov 7, 2018 01:33 PM
rsavelkoul
LR4
Jan 19, 2018 02:25 PM
Clunker
Jul 27, 2011 08:27 PM
