2013 Land Rover LR4 won't start
Old May 15, 2025 | 11:25 AM
irishrover25's Avatar
4wd High
Default 2013 Land Rover LR4 won't start
My rover had been running fine - had taken a couple 2 hour trips with it recently, but I went out to start it last night to run errands and it would not start. Things lit up as they usually do, but push button start did not work - would not turn over. It seems electrical to me - like it is locking up - as I have had no problems starting it leading up to last night. Any trouble shooting/guidance/assistance would be most appreciated.
thank you!!
Irish Rover
Old May 15, 2025 | 09:31 PM
rikkd's Avatar
First thing is to check the battery voltage. Do the interior lights or dashboard flicker while pressing the button?
Old May 17, 2025 | 10:34 AM
4wd High
Thank you - appreciate your response. I will check the voltage of the battery and I'll also check how old the battery is.
Irishrover
Old Jun 8, 2025 | 09:53 AM
BalloonLady's Avatar
3rd Gear
Default Fixed?
Irishrover
did you figure out the problem? I'm having the same problem with mine
Old Jun 8, 2025 | 10:03 AM
3rd Gear
Default Fixed?
Irishrover
Old Jun 10, 2025 | 08:28 PM
Riese's Avatar
If you have one, use a voltage meter to see if the battery has a full charge. Land Rovers are very dependent on a strong battery. It may need a jump to get started. If that is the case you can have it checked but most likely time for a new one. You may also just try cleaning the terminals. They sometimes get corroded.
Old Jun 14, 2025 | 11:06 PM
4wd High
It was deemed that I needed a new battery. I installed it and problem is resolved.
Irish Rover
etylowy
LR4
Jul 18, 2025 09:06 AM
irishrover25
LR4
Apr 27, 2025 09:05 PM
irishrover25
LR4
Feb 3, 2025 04:19 PM
jrod042886
LR4
Apr 10, 2024 05:22 PM
PamelaB
LR4
15
Mar 7, 2023 10:15 PM
