2013 LR4 leaning to the drivers side?
Old Jan 29, 2013 | 07:47 AM
sparrky's Avatar
Default 2013 LR4 leaning to the drivers side?
Not sure if this is normal, but I suspect it isn't.
Today while my LR was parked in Access Height, it looked to be leaning a little to the drivers side. Even when there are no passengers or cargo in the vehicle.
Now that its at Normal driving height, it continues to look tilted a little.
Not sure if its me imagining this.
A few questions:
1) Any way to tell that a vehicle is level? Computer, etc. Or should I try to measure the "level" with a hand level, or by eye?
2) Being a 2013 that I've only had for two weeks. Is this a major repair or a tweak to the air suspension? Or is this something that needs to break in?
Thanks, any help is much appreciated!
Old Jan 29, 2013 | 10:19 AM
ktm_525's Avatar
It is a Land Rover with air suspension, they all eventually learn to do this. It sounds like your LR4 is a quick learner.
Old Jan 29, 2013 | 01:53 PM
Rovin4life's Avatar
seen issues with air leaks from the factory, but disconnect the battery and measure the heights and then if it drops you got a problem.
Old Jan 29, 2013 | 03:45 PM
coors's Avatar
A few questions:
It does not sound normal. Have you tried raising the suspension all the up and then dropping it back down to normal mode. Try cycling through the different modes (range heights). If it still lists take it back and have it corrected.
Old Jan 29, 2013 | 03:56 PM
sparrky's Avatar
I'll fool around with it a little tomorrow and let you know.
Thanks for all of the comments everyone!
Old Mar 3, 2013 | 04:53 PM
csimon's Avatar
any update?
Old Mar 16, 2013 | 05:31 PM
sparrky's Avatar
I raised and lowered it a few times and jumped up and down on the bumper. All seems fine.
It also seems to self correct, sometimes while I'm sitting in it with the engine running waiting for my wife to run into a store, while parked on uneven streets or pavement, etc...
Still only a few months into ownership and getting to know things a little better.
billygoat
Oct 4, 2024 09:46 AM
jeff.marsh
LR2
Feb 24, 2023 06:55 AM
beaubrant
Aug 8, 2014 02:57 PM
pfcboi
LR4
Jan 9, 2014 01:09 PM
disco3ricky
LR4
Sep 15, 2013 11:28 PM
