2016 LR4 landmark ed Fault Codes U0102-00 & C1A20-64.
Old Apr 30, 2021 | 10:29 AM
Ryan2016LR4's Avatar
Exclamation 2016 LR4 landmark ed Fault Codes U0102-00 & C1A20-64.
Hello Everyone,
I am hoping you can help me out. I recently upgraded from my 1996 Disco SE7 to a 2016 LR4 Landmark Ed. Shs has only 60K miles on her, looks and drives beautifully . I however keep getting an amber warning light and a notification that says"suspension fault " Normal ride height only" - So I took it to have a diagnostic and got the following two errors:
U0102-00 - PERMANENT - LOST COMMUNICATION WITH TRANSFER CASE CONTROL MODULE
C1A20-64. - PERMANENT - PRESSURE INCREASE TOO SLOW WHEN FILLING RESERVOIR
Has anyone else had these errors? What is the fix and how much will it cost me? Thank you all so very much for your guidance
Have a great weekend!
Ryan
this ia my girl
Old May 21, 2021 | 09:26 PM
pagoda's Avatar
Originally Posted by luckymike123
Get yourself the tyres and a service done, make sure your windscreen wipers are good and the washer fluid is topped up, tow eyes are accessible and you’ve a strap at the ready. Don’t forget o enjoyTutuapp 9Apps Showbox yourself
What on earth are you talking about?!
To the OP, get a IID tool. Cost you maybe $400. You need to clear the fault codes and see what happens then - ie what comes back. It would seem that you may have a suspension issue, but I'd suggest start with clearing the fault codes and see what comes back. You need to be prepared for a bit of fault-finding. Depending on where/from whom you bought it from you should consider going back to them as it maybe that there's an issue that led to the sale. Air suspension issues are not uncommon, but I'd suggest maybe unusual in a vehicle of this age (quite young).
Report back with findings.
Ryan2016LR4
LR4
May 8, 2021 08:00 PM
waltcmusic
LR4
Aug 13, 2020 08:53 PM
COSPILOT
LR4
Jul 2, 2018 04:20 PM
Disco100
Mar 26, 2010 04:46 PM
