Brake Vacuum Pump Seal/Gasket Oil Leak
I have a 2010 Range Rover Sport. The Brake Vacuum Pump seal was leaking. It is hard to tell if it is the seal/gasket between the pump and the engine block or the seal on the cover of the vacuum pump. I see that the seal between the pump and the engine block is available for around $20-$25. Does anyone know if the seal/gasket for the cover is available? A new OEM pump is $450, an aftermarket pump is $250. My pump is working fine, it just leaks. Thanks in advance. Phil
