Can I disable my electronic parking brake?
Old Dec 5, 2025 | 11:36 AM
VtBike's Avatar
Default Can I disable my electronic parking brake?
Hi LR crew --
My Electronic parking brake has failed for the 2nd time in 5 years... WTF..
It's a $2k job to replace. I'm just done with this thing.. That said, I'm in a habit of using it every time I park, as is my wife. If we pull it now by accident, it engages, faults, and won't release -- rig not really driveable. Got lucky and had it disengage the other day.
Is there a fuse I can pull to just disable it completely?
Thanks so much
Old Dec 6, 2025 | 06:39 AM
guy's Avatar
guy
Failed for the second time... are you using it?? Or is it ceasing?? Or was the fix an aftermarket pos???
Sure you can disable it... but of course by doing so you will disable the operations of cruise control, traction control, dynamic stability control...
And have that annoying warning light on the dash.
Basically, you will be turning your LR4 into a 1970's F150 with a bag of sand put in the box.
Cheers!
Old Dec 6, 2025 | 01:49 PM
Richard Gallant's Avatar
@VtBike I assume you are aware of the emergency release
Old Dec 7, 2025 | 08:09 AM
jastutte's Avatar
well, shoot! that's good info to have.
Thanks, Richard. i hope i never have to use that information, but glad to have it.
Old Dec 14, 2025 | 01:30 PM
pagoda's Avatar
The EPB does need maint at least once a year and if the vehicle is used a great deal offroad and in mud/water, it needs a lot more maint. The process of adjusting etc is well documented - it's a bit of a chore but well worth doing. And as has been noted, it should be used every time the vehicle is parked. It's not a great system, but it's linked to other functions.
Zondar
Jun 28, 2024 07:30 AM
Cziggy
Apr 14, 2023 05:58 PM
mreloc
Jun 13, 2021 04:18 PM
ponderosajack
Nov 4, 2019 04:08 PM
