Can't fill gas tank normally, tank also "burps", 2011 LR4
Old Dec 31, 2021 | 03:44 PM
LR4thewin's Avatar
Default Can't fill gas tank normally, tank also "burps", 2011 LR4
Hi all, I have a 2011 LR4 5.0 V8 with 140K miles.
I can't seem to easily fill up the car with gas. The pump shuts of when I pump at full speed. I can hear that the gas isn't going into the tank quickly enough. I've tried angling the nozzle in different ways. Nothing really helps. Each fill up takes tons of time.
Also, I notice that the tank makes a very loud burping sound back up through the filling tube. This doesn't happen while I am pumping, but while I am driving.
Any thoughts on either issue? Are they related? Thanks!
Old Jan 2, 2022 | 03:54 PM
jlglr4's Avatar
Sounds like problem with the charcoal cannister.
Old Jan 3, 2022 | 08:32 AM
LR4thewin's Avatar
Thanks, I'll start there. Do you have any opinions on the best pdf service manual (or similar resource) for the 2011 LR4?
Old Jan 3, 2022 | 05:04 PM
jlglr4's Avatar
There are some service manuals floating around, but most don’t have the sections dealing with the evap control system (including the charcoal cannister). Try searching in the lr4 forum on landroverworld.com, or on youtube. I know several people have changed them out, and you might find a tutorial. I haven’t done it myself.
Old Jan 13, 2022 | 08:57 AM
LR4thewin's Avatar
Local independent replaced the fuel canister.
Part $299 Labor $337
Issue resolved! Filled up just fine!
willTriBeca
Mar 28, 2024 08:23 AM
Sooners
Oct 25, 2018 12:50 PM
b c
Mar 7, 2014 05:21 PM
Orkney LR4
LR4
Jan 10, 2014 09:04 AM
Torancis_LR
Apr 25, 2009 07:56 PM
