Electrical connectors and suspension compressor issues after accident
Old Jun 29, 2019 | 05:33 PM
urnvs's Avatar
8th Gear
Default Electrical connectors and suspension compressor issues after accident
Im in the final stages of putting my LR4 back together after a lady ran a red light and swiped the front end. There are a couple of electrical connectors on the front left that I cant seem to figure out where they belong. Can anyone possibly shed some light on the situation?
https://photos.app.goo.gl/J1oMHCkc2QLWtZfW9
https://photos.app.goo.gl/nmYLAoDH3t7zkF22A
Also, how is this bracket supposed to attach to the body?
https://photos.app.goo.gl/mnpfVEMnWeVg6uo1A
Finally, the air suspension was working perfectly before the accident, but now I am getting a code "C1A27" on my scanner. Apparently this means that the compressor circuit is open or shorted. Since I was hit in the front, I dont find it likely that something happened to the compressor in the rear, so does anyone know where the wiring to it is routed, and if any of it goes through the front end? Any other suggestions on what to check?
Old Jun 29, 2019 | 11:36 PM
urnvs's Avatar
8th Gear
So to answer the first two questions, the connectors are the TPS receiver and coolant level sensor, which means that the coolant level sensor that came with the tank is plugged into the wrong connector right now.
Old Jul 4, 2019 | 12:05 PM
urnvs's Avatar
8th Gear
Bump - any ideas about where that bracket attaches?
Old Jul 5, 2019 | 11:32 AM
abran's Avatar
Which Bracket exactly? Also, can you upload your photos to this site?
Old Jul 5, 2019 | 08:55 PM
urnvs's Avatar
8th Gear
The one in the 3rd link. The hood release cable goes through it and its supposed to be attached somewhere around the front left fender/core support.
Old Jul 6, 2019 | 02:46 PM
abran's Avatar
It’s mounted to the bracket in front of the p/s reservoir and above the headlight
Old Jul 6, 2019 | 04:18 PM
urnvs's Avatar
8th Gear
Thank! Now its just the suspension issue left to solve. I already tried a different relay and that wasnt it.
viewsonic
Nov 16, 2022 04:58 PM
skb0415
Sep 13, 2019 04:05 PM
Applause
Aug 24, 2014 10:38 PM
alti
Oct 25, 2013 10:45 AM
GCS1
Feb 17, 2008 07:30 PM
