Engine rattling noise??
Old Apr 15, 2024 | 09:30 AM
Gkenneaster's Avatar
4th Gear
Default Engine rattling noise??
My 2016 LR4 has this metal rattling noise coming from the front on the engine area. It had a new lsv6 engine put in September 2023 so I don’t think the timing chain should be worn down. Do yall have any idea what could be making this sound?
The only time the sound comes around is when I am in park, and when I shut off the vehicle as heard in the video. No engine lights or codes in the OSB2 scanner. Engine runs perfect and no leaks.
any advice helps!
thanks!
Old Apr 15, 2024 | 09:36 AM
4th Gear
Preview attachment IMG_9288.mov
IMG_9288.mov
17 MB
Old Apr 17, 2024 | 04:45 PM
sut123's Avatar
I can't seem to get the video to play but I wonder if it's the supercharger? I have the same issue as I just put new timing chains in mine and it still makes a rattle/loose bearing sound and once I pulled the top off the SC I noticed it has a fair amount of play in it. Just a thought!
Old Apr 17, 2024 | 05:38 PM
Hugh166's Avatar
Take off the SC belt and turn the pulley back and forth by hand. See if there is a bunch of slack and you can create a noise from it.
Clement
LR4
Mar 6, 2022 10:22 PM
YoungMC
Sights N Sounds
Jan 21, 2022 11:04 PM
LoneStarLR
May 12, 2021 09:46 AM
Fast951
Nov 30, 2018 08:32 AM
mrcrptguy
Apr 19, 2009 09:49 AM
