Engine rattling noise??
My 2016 LR4 has this metal rattling noise coming from the front on the engine area. It had a new lsv6 engine put in September 2023 so I don’t think the timing chain should be worn down. Do yall have any idea what could be making this sound?
The only time the sound comes around is when I am in park, and when I shut off the vehicle as heard in the video. No engine lights or codes in the OSB2 scanner. Engine runs perfect and no leaks.
any advice helps!
thanks!
any advice helps!
thanks!
I can't seem to get the video to play but I wonder if it's the supercharger? I have the same issue as I just put new timing chains in mine and it still makes a rattle/loose bearing sound and once I pulled the top off the SC I noticed it has a fair amount of play in it. Just a thought!
