Fan Clutch nut not detaching from water pump (2014 LR4 HSE)
I removed the 3 bolts from the water pump pulley which I believe was a mistake because now even when I have a strap wrench on the pulley the nut just keeps spinning and does not come off. You can see in the picture the pulley is a little cockeyed so I'm wondering if I need to put screws back in somehow (not easy btw). There is very little room to work with. Im replacing the water pump and fan clutch so I do not care if they get damaged. I just need them out. Thanks for any assistance you can provide.
