Fan Clutch nut not detaching from water pump (2014 LR4 HSE)
Old Jul 1, 2024 | 04:32 PM
MyLandy2014's Avatar
Default Fan Clutch nut not detaching from water pump (2014 LR4 HSE)
I removed the 3 bolts from the water pump pulley which I believe was a mistake because now even when I have a strap wrench on the pulley the nut just keeps spinning and does not come off. You can see in the picture the pulley is a little cockeyed so I'm wondering if I need to put screws back in somehow (not easy btw). There is very little room to work with. Im replacing the water pump and fan clutch so I do not care if they get damaged. I just need them out. Thanks for any assistance you can provide.
Old Jul 2, 2024 | 03:37 PM
Rustybolts57's Avatar
I believe the bolts have to be in, I can't think of any way to break the clutch free otherwise.
Old Jul 2, 2024 | 08:10 PM
jahummer's Avatar
You must remove the fan prior to the pump. It's quite easy with a fan clutch wrench.
Sgt.Stone
Feb 2, 2013 02:25 PM
1998DiscoverySE
Jul 19, 2012 02:57 PM
rlrigsby
Mar 22, 2010 03:20 PM
BURover
Jul 1, 2009 08:37 PM
herblatham
Dec 8, 2008 08:44 AM
