head gasket?
Old Dec 19, 2018 | 02:50 PM
Gnomadf's Avatar
Default head gasket?
Someone local-ish is selling a LR4 that reportedly has a bad head gasket, well under market because it's going to be an expensive repair. The head gasket itself isn't so bad but labor is going to be pretty intensive, that much I know. Has anyone here replaced a head gasket on the 5.0 or had it done, are these prone to failure? Anything special involved beyond the timing correct? Google isn't helping much.
Old Dec 19, 2018 | 04:22 PM
So it really depends on how bad the motor was overheated. The 5.0 does not respond well to overheating. It could be as simple as having the heads decked and new gaskets but it could have damaged the block meaning new engine time $$$$.
The heads can be done with the engine in, but most folks with the ability will pull the body. while you are in there I would make sure the timing update is done, and replace the water pump.
Old Dec 20, 2018 | 07:19 AM
Nosugar0carbs's Avatar
if You are going to do a head job, make sure to get a helicoil kit as well, you know, for those threads that will get pulled up when trying to torque down the head.
Old Dec 20, 2018 | 07:28 AM
abran's Avatar
Being that you did not do the overheating, I would asssume it needs a motor.
if attempting to do the HG repair the block should be sent out for all head bolt holes to have time serts installed. For some reason those holes end up like cheese after an overheat episode(as stated in the previous post)
Old Dec 21, 2018 | 02:23 PM
Gnomadf's Avatar
And that's the kind of info I came here for, thank you all. Think I will pass. Looks like used motors are >$8K and too much risk in just doing the head gaskets, because I would suspect that they overheated it and drove it until it stopped.
And my garage isn't tall enough for a body off. It looks daunting but my research says it's a 4-6 hour job the first time and down to 2 hours with practice. I find that rather amazing.
lrnoob
Dec 9, 2019 09:56 PM
Lance Hendrickson
Jun 15, 2018 07:10 AM
twin6
Jan 30, 2017 11:15 AM
dave41
Aug 2, 2010 04:42 PM
Gordon Bombay
Dec 15, 2009 11:03 PM
