Help changing power steering fluid
2011 LR4, it is time for power steering fluid to be changed. I have the correct ACE fluid from the dealership. All I have found is pics or a single video from an LR3 which is not as tight as the LR4.
Any suggestions as to which hose and where I can drain the fluid? From there this seems to be a 15 minute change.
Thanks, BD
Thanks, BD
More specifically, I am curious if the small panel in the left wheel well is sufficient to remove, or if there is another plate under the LR4 to remove.
I can see a hose with a clip going into the PS pump, but it seems tough to get at and will pour fluid over a few other hoses on its way to a pan below.
Anyone?
Anyone?
johnnyjohnny
Sep 26, 2019 09:37 PM
josemex
Jul 22, 2009 11:09 AM
jycsalas
Apr 17, 2009 02:21 AM
