Hitachi to AMK compressor conversion kit
Old Feb 18, 2022 | 03:11 PM
DriveBikeRun's Avatar
7th Gear
Default Hitachi to AMK compressor conversion kit
Hello all,
I'm in the middle of replacing my failing Hitachi compressor with the AMK version purchased from Lucky8 for my 2011 LR4. I’m stuck because one of the 3 hoses that came in the pipe kit doesn’t seem to fit no matter which way it is oriented. It’s the largest diameter pipe in this kit and here’s also a pic of the two connection points. It’s possible this is user error somehow, but would really appreciate any help from someone with experience with this job. Thanks so much.
The largest diameter hose in this kit
Not even close to routing the pipe from the vehicle to the location on the new compressor.
Old Feb 18, 2022 | 03:44 PM
DakotaTravler's Avatar
I think is goes over or under the compressor, not around to the back side. Also might have to flip ends around.
Old Feb 18, 2022 | 03:45 PM
Oh, found a pic.
Old Feb 18, 2022 | 04:03 PM
7th Gear
@DakotaTravler thank you! The one orientation I hadn’t thought of 😂. They should really send better instructions with this compressor. They don’t even mention the use of the pipe conversion kit at all!
So where and how are the brass fittings in the kit used? Do you have a picture of that as well?
Old Feb 18, 2022 | 05:37 PM
I think the fittings just plug into the ends of the tubes to reinforce them. This is usually done in a VOSS, not so much with push-connects. So I am not sure if they are critical or necessary.
Old Feb 19, 2022 | 02:49 PM
7th Gear
Thanks again. I just put it all back together without using the brass fittings and all seems fine, no pipes in such a bind where they needed reinforcement IMO. I’ll hang onto the brass fittings just in case, but they really should provide better instructions especially if the parts are different than the originals.
On a side note, reflashing the ECU to work with the AMK compressor was straightforward. The GAP tool did a nice job preparing you to expect the length of time and ignition cycling that was to occur. All seems back in order and the suspension happily changes between modes without faults 😊
Old Feb 19, 2022 | 04:49 PM
Thanks for the update!
moorebl
May 5, 2019 09:37 PM
David Marriott
Dec 22, 2017 12:55 PM
EastCoast
Sep 17, 2016 08:31 PM
