Jaguar engine/ trans?
Old Jan 8, 2024 | 12:10 PM
Stude Lover's Avatar
Default Jaguar engine/ trans?
Hey All, I've been living on this forum now for days reading up on engines, and how to proceed with a blown head gasket (I hoped just the crossover pipes ). I'm thinking about getting a good Jag engine for my 2013 LR4 and doing an engine swap. But before taking that plunge, I'd like advice.
First, the transmission. I do have a line on a 2012 Jag engine, but comes with a 6-speed trans, and he won't separate. Do LR's use that trans? I believe it's the rotary dial selector-- not sure if LR4's would use it. Besides flipping it, any LR need for it?
Ok, back to the engine. I read the two excellent threads on an engine swap out, and in-truck head gasket replacement. I could do either, but with affordable Jag engines available, it would be better as a swap because mines already 137k miles. Also rebuilt long blocks are pretty affordable in comparison.
The Jag engine non-rebuilt-- most are 2012 or older-- should I worry about the timing gear problems with that year Jag engine? Is it a simple swap the oil pan, and connect the LR4 hoses and accessories, and it's good to go?
The rebuilt engine long block-- I might go this way as it's not much more, I have all the LR4 accessories and pan, and we plan to keep the truck for a long time. So, would I run into any unexpected problems going this route?
Both of the swap out and head gasket threads were superb (thanks guys for the excellent effort!!!!), and I could do either, but a Jag engine with new gaskets would also be possible. So, feel free to give me your thoughts and advice. I have the space, a lift, and all the tools for either. Thanks!!!
Old Jan 8, 2024 | 03:23 PM
abran's Avatar
I’m not sure, but I believe that the camshaft pick ups on the jag motor are different than LR pick ups. If that’s the case, you will need to do a semi timing job to change them.
File Type: pdf
File Type: pdf
Old Jan 9, 2024 | 09:42 AM
guy's Avatar
guy
There are a few variants of the ZF 6HP26 transmission. All of which may be fitted with the rotary dial or the shifter.
The right configuration on the ecm and tcm is everything. I would want some guidance on those settings before pulling the trigger on hardware.
You may just be ahead in time, money, and effort to source the LR engine…
Guessers
LR4
May 28, 2023 06:07 PM
merebel
Nov 1, 2021 07:20 PM
MikeGraef
LR4
Oct 11, 2021 04:37 PM
_Gex_
LR4
Jun 17, 2021 10:59 AM
Rover Rebel
Engine Swaps
May 19, 2021 07:25 PM
