Longterm Owners...
Old May 29, 2017 | 08:45 AM
Buckybadger's Avatar
Originally Posted by Jagfixer
I bought a used LR4 with 23,000 miles. PO ha 20" rims and Goodyear Eagles mounted. Dealer did a water pump change and told him he needed brakes and tires. Inside the vehicle were 4 original tires and rims with no wear. I bought and immediately changed to the original tires and wheels. I put on new pads and had a continuous smell of hot antifreeze. Seems dealer did not wash out antifreeze when they dump antifreeze to do the job. The new pads went to 60K (37K miles) I then put rotors and pads at the 60K mark and at the now 73K pads are way within specs. I tow 16' car hauler and a 26' boat trailer and I figure to hit 100K or more on pads. When dealer does work, you have to check. He spoiled you with the antifreeze spell to sell. Mine will be around for a long time, never being touched by dealership.
Didnt smell any burning of antifreeze- did a pressure check for no leaks first. Then after that passed I was still losing about a quart of antifreeze a month. Other than replacing the Water pump (which I did ) the antifreeze can only be going one other way.
The bottom line is that I drove Land Rovers for roughly 10 years and finally had enough of the breakdown crap. And now that they sissified the entire lineup (the LR4 being the last of a true LR look) they lost me and quite a few others.
Old May 30, 2017 | 07:30 AM
iconoclast's Avatar
Originally Posted by Buckybadger
The 2014 with the V6 was a superior vehicle.
what made it "superior"?
Old May 31, 2017 | 08:38 AM
IMO the SC V6 is a much better setup with the 8 speed transmission- smoother setup. I believe it was still about 280 hp. And actually was more responsive.Gas mileage was better as well. Also the newer generation 2014-16 had much lower incidents of electronics problems for whatever reason. IF however your plans are to pull a camper or boat (over say 6000# )then perhaps the V8 is the way to go.
Old Jun 4, 2017 | 03:02 PM
iconoclast's Avatar
340hp is what the specs seem to be. Not sure if you're in another region which received a different motor. The V8 I believe is 375 or 380.
Old Jun 5, 2017 | 07:55 AM
Yes your correct - my mistake. HP I quoted is on my 4runner not the LR4.
Old Jun 13, 2017 | 07:56 AM
paintpollz's Avatar
Originally Posted by BritCars
We've had our 2010 LR4 the past 4+ years and it has been terrific. 75k miles and still feels and drives wonderfully
Water pump, a door lock actuator (both on warranty) front lower control arms and a couple of sets of brake pads - and that's about it.
I would highly recommend!
seems pretty damn good for LR. This is what I was hoping to hear, as I may make the switch from a Tahoe.
Old Jul 18, 2017 | 09:35 AM
Nettek's Avatar
So all my issues have been electrical components in my 2011. Bought as a service vehicle w 65 miles.
This year we've had to do water pump, control arms and timing belt tensioners - all under warranty. Never had a break down of mechanical nature but several component failures. Early on had the fan clutch freeze on high and that was easily replaced.
We drive up to the mountains frequently and love the performance of the 5.0L V8 engine. I've only driven the V6 discovery sports but do not enjoy the transmission's shifting and lack of power off the line when taking off from a stop I find it unpredictable and cannot imagine it in the heavier LR4 body.
We are getting 38k out of the Cooper tires vs 22k in most other brands.
Old Jul 19, 2017 | 10:15 AM
iconoclast's Avatar
Excellent. Glad to read most are having trouble-free experiences with their vehicles.
modyfyit
ROAMING WITH FRIENDS
Sep 28, 2005 02:44 AM
freshtudef
Aug 18, 2005 11:49 PM
beavis4g63t
Jul 27, 2005 10:46 PM
DIMISA1977
Jun 2, 2005 01:47 AM
brad
Feb 7, 2005 09:54 PM
