Lots of white smoke
Do you have any codes? Is it misfiring? Sometimes the fuel injectors stick open dumping fuel which can't be burned. This causes white smoke too and is a lot easier than a coolant entering the cylinder issue, so I'll keep my fingers crossed for you.
make sure your PCV valve and vacuum pumps are not the culprits before you jump off a bridge.
https://www.landroverworld.org/threa...-3#post-248780
tensegrity
Aug 13, 2016 01:21 PM
