LR4 gearbox fault
Old Nov 28, 2019 | 04:44 AM
  #21
Sergey Zubakov's Avatar
8th Gear
gregstevens67 - i found you error, first - please check a solenoids (just electric tester), second - buy a repair kit from ZF for 6hp26 and set it on you mechatronics , third - change oil.
I hope it help you with you problem.
Old Nov 28, 2019 | 04:46 AM
  #22
Gasa's Avatar
6th Gear
Hi, error is "Gearbox Fault" "HDC not available system fault"
Old Nov 28, 2019 | 04:50 AM
  #23
8th Gear
WOW may be easy, look at https://www.landroverworld.org/threa...x-fault.30703/
Old Nov 28, 2019 | 04:52 AM
  #24
8th Gear
also check main battery
Old Nov 28, 2019 | 05:04 AM
  #25
Gasa's Avatar
6th Gear
I have a new battery in mechatronic tested all working fine but still the problem wont go away.
Old Nov 28, 2019 | 05:05 AM
  #26
Gasa's Avatar
6th Gear
Thank you for the link I am following through...
Old Nov 28, 2019 | 06:16 PM
  #27
gregstevens67's Avatar
Sergy I think my problem is in the gear select slider where it meets the hall sensor. Will strip it down Monday for a more thorough inspection....Will let you know.
Thanks so much for your input.
Cheers Greg
Old Nov 29, 2019 | 02:56 PM
  #28
Hi Gasa, where are you at with your gearbox fault...Whats your thoughts on the gear sensor pcb replacement video from Sergey? Do you have P081C-64 Fault code?
Old Nov 29, 2019 | 03:28 PM
  #29
Hi Sergey, how did you get the gear sensor pcb out of the housing? Video doesn't show how? What did you use to insulate the new pcb, resin? Cheers Greg
Old Dec 7, 2019 | 05:31 PM
  #30
Default Gearbox fault
Hi guys, contacted ZF direct and spoke to a tech. He reckons the trans is fine and is pointing at the shifter! Have one on the way, will keep you posted.
