LR4 gearbox fault
Old Dec 14, 2019 | 05:04 PM
  #31
gregstevens67's Avatar
Hi Everyone, Yes all faults gone......FAULTY SHIFTER!!!
Old Jan 2, 2020 | 10:33 PM
  #32
LR4play's Avatar
What was the total cost for replacing the shifter?
Old Apr 29, 2021 | 03:48 AM
  #33
Ominub's Avatar
Originally Posted by abran
Those are generic codes. Buy the GAP, it will cost the same amount as the dealer will charge to read codes.
if you want to continue with this vehicle, buy the GAP.
Hello, please what does it mean, the "GAP" ... I ve bought now US version 5.0 V8 2011 LR4 and I have several problems with that including this one. Thank you in advance.
That one? https://www.ebay.com/itm/Land-Rover-...0aAr3hEALw_wcB
Old May 11, 2021 | 07:16 PM
  #34
Jose Aguilar's Avatar
4th Gear
I have a faulty LR4 showing the following faults from my GAP tool:Vehicle scanned on 01-05-2021 14:50
Using IIDTool BT V4.0 B2742
ABS-Brake Module
  • U0402-68 (AB) Invalid data received from transmission control module - Algorithm based failure - event information
    ( on 01-05-2021 14:27:35 at 75787 km )
IPC-Instrument Pack
  • U0128-00 (2E) Lost communication with parking brake control module
    ( on 01-05-2021 14:49:59 at 75787 km )
PBM-Parking Brake
  • U0402-00 (2B) Invalid data received from transmission control module
    ( on 01-05-2021 14:26:38 at 75787 km )
TCCM-Transfer Case
  • U0402-00 (2F) Invalid data received from transmission control module
    ( on 01-05-2021 14:26:44 at 75787 km )
TCM-Transmission 6spd
  • P0915-01 (AF) Gearshift position - circuit range/performance - General failure information - general electrical failure
My indy mechanic is pointing to a possible change of the TCM (transmission Control Module). I wanted to know if these errors could represent a problem in the shifter instead of the TCM. The shifter change is way cheaper than the mechatronics.
Happy to hear your comments.
JAA
Old Aug 9, 2021 | 07:20 PM
  #35
4th Gear
Default Hello
Originally Posted by gregstevens67
Hi guys, contacted ZF direct and spoke to a tech. He reckons the trans is fine and is pointing at the shifter! Have one on the way, will keep you posted.
I just wanted to know if you have the part number for the LR4 shifter? A picture of the shifter you replaced?
Thank you
JAA
Old Jul 23, 2022 | 04:54 PM
  #36
JBAa's Avatar
ABS-Brake Module
IPC-Instrument Pack
PBM-Parking Brake
TCCM-Transfer Case
JAA
Hi Jose, and anyone else
Did you solve Your problem? I also get similar codes. Especially U0402 (xx).
My car starts of fine, but when the engine gets warm, or after driving about 10min I get the “gearbox fault” in my screen and the car goes in to limp mode.
normally I just keep driving in limp mode, and the next time I use the car all is good again. But some times I can not stop the engine, and the Screen says The gearbox is not in park. By clearing the fault I manage to stop the car.
I have changed the brake switch, transmission oil and filter, connector sleeve on gearbox. Next will be to check and clean all modules and connectors I can reach without to much disassembling. But I would really like some hints from anybody that has had U0402 “gearbox faults” and solved them.
John B
Old Mar 10, 2025 | 06:57 PM
  #37
4th Gear
Default Problem solved
John B
Hi. I did solved my problem but it was through a third party. My transmission was mechanically Ok, but the control system was not working properly. I had it removed from the transmission (a whole ordeal) and send it to Softelectronic 1 Ltd. in Bulgaria. They have developed the knowledge to repair this fault (At least the fault that I had). The issue is that the control system has problems and needs to be fixed and very few people know how to do it. Please contact Boris Georgiev, Sales Manager. email: admin@softelectronic.com. The LR4 is working fine. I have other issues, not direclty linked to this one, but the transmission seems ok, so far, and its been some years now. Hope this helps.
mirepoixmatt
Nov 11, 2021 06:32 PM
tchaudhry10
Apr 18, 2019 04:28 PM
mirepoixmatt
Mar 3, 2014 09:53 PM
