Lr4 possible catalytic issue but i don't know at this point
Old Aug 21, 2021 | 03:53 PM
laughlin321's Avatar
5th Gear
Unhappy 2011 Lr4 possible catalytic issue but I don't even know at this point. PLEASE HELP!
2011 LR4 (133K). Recently had both side of injectors replaced. For some reason the 4 cylinder had to be replaced twice after the initial repair. I am now getting catalytic codes which my mechanic is "pretty certain" it is the catalytic converter from fuel dumping in injectors from issue with fuel injectors before replacement, but was advised by mechanic it "should" run fine with check engine light on solid until catalytic converter replacement. Now, it will just die, all lights (cruise control, restricted performance, and sometimes many other random warnings) will come on. I turned off and back on and it will drive until it happens again 10 minutes or so later. Today, in 100 degree weather the lights and dying happened immediately. Could this be a catalytic converter issue or something else? I have went through my savings trying to fix this LR4 and cannot afford to just throw money at a maybe problem. Please help!
Old Aug 26, 2021 | 05:13 AM
5th Gear
No one seriously???
Old Aug 26, 2021 | 01:40 PM
jlglr4's Avatar
Originally Posted by laughlin321
2011 LR4 (133K). Now, it will just die, all lights (cruise control, restricted performance, and sometimes many other random warnings) will come on. I turned off and back on and it will drive until it happens again 10 minutes or so later. Today, in 100 degree weather the lights and dying happened immediately. Could this be a catalytic converter issue or something else? Please help!
No, I can’t think of any reason this would relate to the catalytic converter. This sounds like a dying battery or bad alternator, but could be a whole host of other issues, e.g., faulty battery management system, loose ground wire someplace, water damage to central junction box in the passenger compartment (sunroof drain leak?). Do you have a scanner to gather codes?
zracin
Jan 23, 2024 10:19 AM
Luis Fernando Gutierrez
LR4
76
Apr 15, 2022 11:22 AM
DaveLr4
LR4
Nov 8, 2020 03:33 PM
