LR4 w/ 66K : Too many miles?
Old Sep 27, 2013 | 07:54 PM
KCexpat's Avatar
3rd Gear
Default LR4 w/ 66K : Too many miles?
Hello all. Need some advice before taking the LR4 plunge. I found an LR4 in the color combo I want (fuji white ext, black int) for $33K, which sounds like a good deal. But should I leave it alone because it has 66K and is not a CPO vehicle? Checked Carfax and it has been regularly serviced at a Land Rover dealer, including the 50K works.
I welcome your input.
Old Sep 27, 2013 | 09:02 PM
If no warranty any vehicle can be costly to fix.
The maintenance by a dealer may not be as much as you would like. The maintenance list will include things like 10 year drain interval on the differential, when it used to be annual or after wading, etc. The front diff takes under a quart of fluid, and costs over $2000 to replace. Fluid is cheap. Rover frequently considers short trips, long idle periods, as "arduous service" and expects more frequent oil and fluid changes. So mall crawling and waiting in line at the drive thru and school pickup might more frequent than 10,000 mile oil changes. My opinion of the factory service intervals is that if done by schedule 95% of trucks will make it past warranty by 2 weeks. If you want longer life, shorten the intervals.
Old Sep 30, 2013 | 04:05 PM
BritCars's Avatar
My experience is it's very hard to tell by mileage alone. A vehicle that has mostly done stable cruising at highway speeds and a high mileage could well be a better bet than a low mileage city runabout that has constantly been start-stopped, lots of turning, brakeing, hitting curbs etc...
As Savannah Buzz says, maintenance on any used vehicle past its warranty can be expensive, so mileage isn't necessarily the only factor.
I'd look at how much you're saving vs. a lower mileage version of the same model and year, and make the call on whether that gives you comfort. If it's just $1000 on a vehicle of this value, I'd personally go lower mileage. If it's $5k then you have a pretty big buffer if something goes wrong.
You didn't mention the year, so hard to know if the price is reasonable. I bought a 2010 LR4 a full year ago now with just 35k miles and it was under $40k. So you might be able to trade model year and miles off a bit too.
If in doubt, there are plenty more LR4s around!
Old Oct 1, 2013 | 04:54 PM
KCexpat's Avatar
3rd Gear
The price just dropped again - now it's down to $31,999. Thoughts on that price for an LR4 with 66k?
Old Oct 1, 2013 | 05:02 PM
Eldonkey's Avatar
How does that compare to KBB? I would guess you could find a similar vehicle private party sale for about the same.. Is this through a dealer?
Old Oct 1, 2013 | 05:06 PM
Eldonkey's Avatar
Here is a similar listing near me..
Used 2010 Land Rover LR4 For Sale | Tulsa OK
Old Oct 1, 2013 | 08:47 PM
KCexpat's Avatar
3rd Gear
It's through the local BMW dealer. The price is well below KBB. It's not CPO (which we'd prefer) but the chances of the right color combo coming up at our LR dealer (which has only had 2 LR4s in the past 6 months) aren't great.
Heart says "do it", head says "hold on a minute"...
If anyone else on the forum has experience buying a higher mileage LR4 I'd appreciate your insight. Thanks to those who've already commented.
Old Oct 1, 2013 | 10:14 PM
Eldonkey's Avatar
In the words of disco mike and savannah buzz, get a pre purchase inspection done at an independent shop specializing in LR.. It's worth the $150 if you are on the verge of purchase
Old Oct 6, 2013 | 10:58 AM
Stepsride's Avatar
Car fax or equivalent, service records or if they are a DIY service book and receipts. Also if itis too good to be true it probably is!
WildCJ5
Nov 2, 2024 04:47 PM
Waltmink1
36
Jan 19, 2011 06:45 AM
jasoncrew03
Nov 15, 2010 09:48 PM
bikingteacher
Jan 10, 2010 08:21 AM
phia@binoco.com
Dec 10, 2006 11:23 PM
