Pesky P0496 keeps coming back
Old May 2, 2019 | 09:41 PM
Rufflyer's Avatar
Default Pesky P0496 keeps coming back
Specifically:
PCM-Engine Petrol
P0496-00 (E8) Evaporative emission system high purge flow
( on 23-04-2019 17:46:34 at 96896 mi )
Dealer replaced the purge / solenoid valve last spring. Code stayed off for 3 months, I reset it and then it came back after 2 months. And now it seems to show up every other thank of fuel. It does not care if I use regular unleaded or premium, same results
I have pulled the LR brand valve, cleaned the hoses and plastic parts and reassembled 3 months ago.
I have replaced with another LR brand valve last month.
I just pulled it off and made sure all of the connectors were tight.
Tonight while clearing the codes, I decided to look at live values. Knowing that there are some things that can be read on the LR4 that cannot be read on the LR3, I took a chance and found a live value in the untested section.
I do not know if the times listed are within the limits or not, but I suspect a leak in the hose somewhere between the valve and the fuel tank or a second bad valve, but without knowing how long it should take to pressurize, I am just guessing.
Does anyone know the pressures or times that will make the computer happy?
Jeff
File Type: pdf
austinlandroverbill
Jul 5, 2017 11:11 AM
aemnky606
Mar 25, 2017 07:16 AM
RANDY04D2
May 30, 2014 12:53 PM
Joshman
Mar 3, 2014 06:24 PM
aublec22
Jun 10, 2009 05:25 PM
