Rear Camera Replacement
Old Mar 11, 2023 | 05:34 AM
GBO's Avatar
GBO
3rd Gear
Default Rear Camera Replacement
Hello,​ I have a 2015 LR4 and our rear camera has become so foggy and scratched that I need to replace it. I purchased the replacement parking camera part LR052028. Does anyone know how to access the camera to replace it? Wondering if I need to pull off the rear top lift gate trim to remove the entire lift gate panel or if I can access it from the outside. Thanks in advance!
Old Mar 12, 2023 | 07:42 AM
guy's Avatar
guy
its just a plastic lens…. I’m surprised you couldn’t just use headlight restorer and sealant and have it behaving like new in 15 mins.
Old Mar 14, 2023 | 07:36 AM
keninnc's Avatar
You will need to removed the interior trim from the upper lift gate. 1 screw that holds on a small piece of trim at the locking mechanism. 3 Torx screws under the seal. Then after you remove the trim there are 4 10mm nuts that hold the handle assembly ( part that houses the licence plate bulbs and the camera) to the rear lift gate.
Old Mar 15, 2023 | 06:37 PM
GBO's Avatar
GBO
3rd Gear
Thanks Ken! Wonderful, detailed description.
stsao
Feb 6, 2025 04:00 PM
taylo951
LR4
Mar 11, 2023 05:35 AM
Poinssixoneeight
May 24, 2021 01:09 PM
Corpraider
LR4
Sep 30, 2016 04:48 PM
avraja
LR4
Apr 19, 2013 12:48 PM
