Sunroof leak but not the drain
Old Nov 20, 2024 | 04:30 PM
Rlutterb's Avatar
5th Gear
Default Sunroof leak but not the drain
I have a 2012 Land Rover LR four with water coming in between the headliner and the windshield and running down the driver side a pillar. I totally disassembled it and used weedeater line to check and make sure that the drain is not clogged from the sunroof down to the L nipple up under the dash. When I pour water into the sunroof track up top, water comes down plentiful out of the disconnected hose under the dash. Unfortunately it’s also leaking in a bunch of other spots up under the headliner which kind of makes me think that the whole sunroof track is cracked? Anybody ever have this issue before. You can see in the picture that the Red Circle, #1 is the drain line connection and it is not leaking. The things numbered 2 3 and 4 are where water is coming out. I’m sure it’s running from someplace else but I can’t figure out where. I’m only dumping water in the sunroof track directly above the driver door to test it. I don’t see any leaking on the passenger side.
Driver side sunroof drain area with headliner removed
Any help is appreciated
Old Nov 22, 2024 | 03:45 PM
Rlutterb's Avatar
5th Gear
sure could use some help on this one
Old Nov 22, 2024 | 06:36 PM
guy's Avatar
guy
Jeepers… that is worrisome. I’m going to check mine in the morning.
Old Nov 30, 2024 | 09:48 PM
archaeology_student's Avatar
Where the line joins to the track it can crack. Also, try checking the line again. I had so much debris in mine that I had to use the trimmer line about three times in 3 weeks… it kept clogging with debris / gunk in the line.
to test I used a little soapy warm water to help loosen / dislodge and gunk left in the line and once I saw a steady stream I was happy.
Old Dec 6, 2024 | 09:44 PM
KyleP's Avatar
The next time it’s raining go out and take the sun visor off on both sides and the grab handles in the front off. Pull the headliner down up at the windshield and make sure it isn’t your windshield leaking. These are known to have leaks in the windshield rubber.
Old Apr 19, 2026 | 12:02 AM
erik_7's Avatar
Default Any follow up or solution?
Hi, may I ask what’s the eventually fix on your case? Felt I have the same problem
Old Apr 19, 2026 | 08:04 AM
KyleP's Avatar
if you’re asking me I replaced the windshield which fixed my problem
Old Apr 19, 2026 | 10:25 AM
Rlutterb's Avatar
5th Gear
Had to remove the front half of the headliner to get to the drain tubes and clear them
Painful but all labor no new parts
greisinb
Oct 14, 2022 02:42 PM
Fairview
Aug 17, 2011 05:45 AM
Gerard
Feb 20, 2011 06:54 PM
marlymarl
Apr 12, 2010 02:00 PM
nynole
Feb 26, 2008 06:04 AM
