Thoughts, please!
Old Mar 16, 2023 | 10:33 AM
humroot's Avatar
Default Thoughts, please!
Hi all,
I found a 2015 LR4 that I am going to look at tomorrow. I called the dealer where the truck has been serviced, and the service guy was awesome and told me it was a well maintained truck. He knows the truck and the guy who owned it. He told me the last time the owner was in he needed some work, he declined and traded it in.
What has been done:
  • Control arm bushings
  • Supercharger nose cone
What NEEDS to be done:
  • Valve cover gaskets
  • Upper coolant pipe
  • Sealant for upper timing chain cover
  • Lower Supercharger gasket
  • Vacuum pump gasket (vacuum pump is fine)
I already know that I need to replace the front and rear coolant crossovers. So I am wondering from the list that needs to be done, are most of the items ancillary based on changing the valve cover gaskets? How hard is replacing the VC gaskets?
Appreciate any thoughts on this. I dont mind doing the work, but not if it's a huge job like the HG's on a D2.
Thank you!
Jamie
Old Mar 16, 2023 | 06:35 PM
jahummer's Avatar
The vacuum pump's a common leak and easy to repair for a few dollars, valve cover gaskets are also a common failure but take a lot of labour but part of that includes replacing the coolant pipes and super charger gasket required when doing all of the other items so honestly not much at all in total. However, there's more to these trucks than that and over time you'll find yourself replacing many parts as they fail, and they will. Read these forums for more info.
Old Mar 16, 2023 | 11:08 PM
humroot's Avatar
Thank you. Exactly what I was looking for.
I have a 2001 D2 that I bought 22 years ago. So not unfamiliar with land rover ownership. Appreciate the response!
lasoundguy
May 16, 2023 03:31 PM
Fast951
Sep 28, 2018 09:45 PM
grasshopperdisco
May 28, 2014 01:44 PM
BFox15
Sep 7, 2011 08:22 PM
humroot
Nov 4, 2007 12:05 PM
