UV Dye
I'd suggest you buy a black light (UV) first and check whether the coolant is UV refractive. Many are and you'll probably find you're ok. If you've used LR-spec coolant (eg Pentofrost, I think in the US and yes it's orange) it will show up. I had a tiny coolant leak and using black light found that the whole thermostat housing was breaking down; the black light showed multiple tiny fractures where coolant was seeping through. The dye they sell is more commonly used for oils where there is very little/no UV refraction.
