UV Dye
Old Dec 8, 2020 | 08:31 PM
MichiganRover's Avatar
Default UV Dye
Has anyone used a UV dye to find a coolant leak? Sounds like it works great just dont want it to change my coolant color. 2012 LR4 HSE - orange coolant. Looking for recommendations.
Old Dec 10, 2020 | 06:01 PM
jlglr4's Avatar
I haven’t used it, but I understand you need to get the UV dye that is formulated for the orange coolant (Dexcool long life coolants). I know ACDelco sells one, and I think NAPA auto has their own as well. Probably some others. Those dyes shouldn’t change the color of the coolant.
Old Dec 11, 2020 | 06:43 AM
pagoda's Avatar
I'd suggest you buy a black light (UV) first and check whether the coolant is UV refractive. Many are and you'll probably find you're ok. If you've used LR-spec coolant (eg Pentofrost, I think in the US and yes it's orange) it will show up. I had a tiny coolant leak and using black light found that the whole thermostat housing was breaking down; the black light showed multiple tiny fractures where coolant was seeping through. The dye they sell is more commonly used for oils where there is very little/no UV refraction.
Old Dec 11, 2020 | 10:52 AM
Thanks lads
grapple
LR4
Feb 15, 2020 01:24 AM
Amberslaws
LR4
Oct 1, 2019 11:48 AM
Chris Charlton
LR4
Aug 2, 2019 01:11 PM
flavo
Jan 10, 2014 08:32 AM
cruzin
Nov 14, 2008 07:30 PM
