X-Engineering X-Caps - $18
A good looking and functional replacement for the nasty plastic caps supplied with modern vehicles. The X-Cap can be removed with any multi-tool: most spanners (edge on): 27mm wheel wrenches and if you have nothing else: even a stick will do.
It will fit the vast majority of Land Rover vehicles plus others with a 3/8 BSP thread.
It is designed to fit in the top of the radiator on PRE Td5 engines. The Td5 has a plastic bleed plug in one of the hoses which is a different size. It will also fit the Axle Filler plug on Discovery 2 and in to the thermostat housing on 300Tdi engines.
https://www.lucky8llc.com/products/x-engineering-x-cap
0304Disco
Jun 5, 2011 08:11 PM
