02 DII 4.0 to 4.6 conversion NOT SWAP Q's
Old Nov 16, 2014 | 09:08 PM
badassbmwm3's Avatar
Default 02 DII 4.0 to 4.6 conversion NOT SWAP Q's
I've done some research and found a lot of people swapping the entire 4.0l motor out for the 4.6l, but I also come across some information suggestion the block are the same for the two motors.
Can anyone verify this? Also, if that is the case does anyone know which parts are reused from the 4.0 and which parts must come off a 4.6 to make this work properly?
Seems like it could save some money doing it this way and I'm not rich but am handy with tools.
Any help would be greatly appreciated.
Old Nov 16, 2014 | 10:45 PM
dusty1's Avatar
yes block is the same...same heads....
you need the 4.6 rotating assembly.....whichever pistons you want
the computers are adaptive, but a matching 4.6 ecu should make it easier
Old Nov 17, 2014 | 06:09 PM
Default Thanks
Excellent, finally some good news lol.
I heard the 4.0 pistons raise the compression a little and are better. Has anyone found this to be true?
Anyone have these parts laying around to sell me?
I believe the mass air flow sensor needs to be changed along with the top portion of the intake air filter box and piping to the throttle body correct?
Thanks
Old Nov 17, 2014 | 08:33 PM
dusty1's Avatar
High comp. pistons are offered for both, but yes the 4.0 is going to be higher compression w/ 4.6 assembly
Old Nov 17, 2014 | 09:21 PM
Default hp and torque?
So doing the 4.6l swap with all the parts I've mentioned such as 4.0 pistons, larger maf and larger intake what should I expect roughly for hp and torque?
Any reason to do oil pump or anything else while I'm in there?
Old Nov 17, 2014 | 09:29 PM
dusty1's Avatar
Factory 4.6 specs max it at 217hp at 4500 rpm and 300lbs at 2500rpm
Who knows w/ the tweaking...cams and whatever
4.0....182/243
Depending on miles oil and to timing set could be a great idea
bennyb43
Dec 11, 2013 08:17 AM
Paul Grant
Dec 11, 2011 05:50 PM
tulsadiver
Jul 7, 2011 04:34 PM
tulsadiver
Jul 6, 2011 02:11 PM
NiteTrain
Mar 22, 2010 11:21 AM
