Can bus
Old Nov 4, 2012 | 06:02 AM
Landyman37's Avatar
Default Can bus
Hi I am currently fitting a discovery td5 engine into a defender tdci. The problem I have is connecting the engine up to the dash. The dash seems to be can feed to work the temp gauge charge light glow plug light mil light and rev counter. I am looking for some sort of converter.
Thanks for you help
Mr green
Old Nov 4, 2012 | 10:14 AM
Rovin4life's Avatar
Sorry but you need the ecu, the tcu, and the instrument cluster and the bcu to get it to work as all are apart of each other. You need to check out land rover uk for issues and modifications.
Old Nov 18, 2012 | 11:40 AM
BBS GUY's Avatar
Mr Green
The CAN Bus is a very sophisticated data communication network that cannot be simply interfaced with older analogue equipment like the TD5 EMS.
If you are retro fitting old technology like a TD5 engine and ECU, you should also replace your Instrument pack for the equivalent technology version too.
Phifross
Jun 7, 2017 07:58 PM
Disco2 MTL
Dec 15, 2014 01:18 PM
Dave Plummer
17
Jun 17, 2012 08:18 PM
Darover
Oct 28, 2009 08:19 PM
jmerrill
Mar 5, 2006 01:38 PM
