converting from Air suspension to coil spring, ple help
Old Nov 16, 2010 | 10:18 PM
Explorer0863's Avatar
My reason for replacing my air suspension was financial and I was looking for a trouble free operation. Simply wanted to forget about the air bags leaks and the cost associated with replace them + the issues that you are experiencing. Since changing it to Old Man Emu springs and shocks many years ago, I haven't experienced any issues at all. I did the job myself and it was fairly easy. After completing the job, I had better clearance and was able to install bigger/more aggressive tires.
This was for my RRC. I do realize that you own a Disco, but wanted to share my experience, from a RRC owner perspective. I hope this is helpful.
Old Nov 18, 2010 | 08:28 PM
Danny Lee 97 Disco's Avatar
I would also want to compare the cost of each. And possibly even a more durable air suspension. Possibly upgrade the plumbing to a more durable material/construction like the aircraft style pneumatics.
All depends on your degree of disposable income compared to your overall desires.
Adjustability may be nice while a really good heavy duty coil spring/shock combo may better suit your specific needs.
Old Nov 30, 2010 | 02:27 PM
NW_rockhound's Avatar
I like the air SLS on my D2 because the ride is nice and after overloading the back of it with wood/building supplies and a trailer it comes back up to normal ride height. And it still rides comfy with a load in it!
Add to this I can raise the rear by a good 3 inches when off-road with the push of a button!
I just had the same issue the OP had with saging rear when parked. Used soapy water in a spray bottle and discovered a pinhole in the left spring. $230 for BOTH rear bags WITH a lifetime wty, now the truck rides like new - problem solved.
No trip to Land Rover to reset/disable the "system."
Easy repair in your own garage.
Old Nov 30, 2010 | 03:11 PM
You can also add up to a 3" lift along with the SLS and have the best of both worlds.
TRIARII
Jun 30, 2022 09:48 AM
texci77
May 26, 2012 09:47 PM
b_woodroaster
Nov 5, 2010 08:54 AM
catchthebig1
Sep 24, 2010 11:57 AM
FordCrusherGT
Jan 10, 2007 02:15 PM
