Engine/Transmission swap Questions
Old Feb 15, 2009 | 01:08 PM
Kennyr996's Avatar
4wd High
Default Engine/Transmission swap Questions
I have a 95 Disco with a 3.9 and automatic transmission. I am interested in swapping it out with a 4.6. I am also interested in possibly swapping out the tranny at the same time for a 5 speed. How much work is involved? Would the 5 speed need beefing up? Also, is it possible to put an ashcroft gear reduction on the 5 speed? Thanks in advance.
Old Feb 15, 2009 | 01:33 PM
It can be done, it will take some effort but a 4.6 short block could be installed, so could a 5 speed, but I am not sure why you would wnt a 5 speed and if you can find a good one that has not been damaged.
Old Feb 15, 2009 | 02:50 PM
Kennyr996's Avatar
4wd High
The reason behind the 5 speed is that I was given the chance to drive a d90 with a 5 speed and a 3.9 and the difference between it and my disco with an auto was amazing.... Very responsive for a 3.9, i can only imagine with a 4.6 and some regearing...
Old Feb 15, 2009 | 04:12 PM
Sure there is a difference, around 1200 #s lighter, it wasn't the 5 speed, plus a Defender has a lower gearing in the t/case which will maker it more responsive.
Old Mar 1, 2009 | 08:48 PM
Fivespddisco's Avatar
I have a 5 spd in my D1 with 4.6 and it is great but not even CLOSE to the pep " if you can call it pep" of a D90 5 spd with and a 4.6. Weight is a killer.
reporob
Feb 27, 2014 07:30 PM
bennyb43
Dec 11, 2013 08:17 AM
discomedic4
Mar 27, 2010 07:03 AM
GASportsCar
Jul 17, 2009 08:37 AM
tunernewb92
Jun 23, 2009 04:44 PM
